Likes Likes:  4
Results 1 to 19 of 19
Thread: in-dash indicator lights
    10+ Posts STAUSH's Avatar
    Aug 2018
    LAS VEGAS
    Default in-dash indicator lights
    Has anyone relocated their turn signal indicator lights to a different position? I hate where the indicators are located on the freewheelers. Takes your eyes off the road for too long a time to see if they are flashing. I would like to relocate mine up on the nacelle so I can see them by just glancing down with my eyes instead of tilting my head down. Having bifocals doesn't help either. Any suggestions would be helpful.
    Thanks, Staush
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Have you asked your service manager were you bought your Freewheeler about what would be involved?
    200+ Posts
    Sep 2018
    Pa
    Default Turn signal mirrors
    Quote Originally Posted by STAUSH View Post
    Thanks, Staush
    How about something like these.
    https://www.amazon.com/HTT-Motorcycl...gateway&sr=8-6
    Aug 2018
    LAS VEGAS
    Default indicator lights
    As far as getting info from Harley, no way. would drather get information from the forum,usually tried and true. Don't want to put on mirrors, just some small lights on nacell. Good thought about the mirrors Tucci, will look on Harley web site on how they connect them on a freewheeler and will substitute small indicators instead of mirrors.
    Thanks Guys
    50+ Posts
    Aug 2018
    Sand Springs,Oklahoma
    Default Blinkers
    It would be simpler to leave the factory ones as is and just wire a set of aftermarket LED pod lights into the front blinker wiring - You can mount the LED pods just about anywhere you like - Perhaps on the top of turn signal pods or the back side of the windshield - Very easy
    200+ Posts
    Sep 2018
    Pa
    Default Turn signals
    Where I live, no one uses turn signals. They don't want to make a commitment until the very last second before they turn in front of you.
    Aug 2018
    LAS VEGAS
    Default indicators
    Nobody uses signals anywhere. Using PODS is a good idea. Checked Harley wiring and the mirrors connect directly into turnsignal wiring so why not any other leds. thank you
    200+ Posts
    Sep 2018
    Pa
    Default LED PODS
    Quote Originally Posted by Sugarbear View Post
    I 👍 like this idea, thinking about setting them up so they would be visible to anyone approaching directly from either side.
    300+ Posts
    Mar 2018
    Waelder, Texas
    I have been using Radantz Haloz front turn signal LED clusters on my Freewheeler for about a year now. They are white for DRL and flash amber/white. Very bright,too. Anyway, I can see them flash from a normal riding position even in bright sunlight. No need to look for the indicators on the dash.
    950+ Posts Free Bird's Avatar
    Mar 2018
    Saint Louis
    Has anyone relocated their turn signal indicator lights to a different position? Thanks, Staush
    I had a similar thought when I was relocating mine due to a front end swap (for a springer) that did not happen. But in that effort, I bought a set of Rivco Mirrors for the same reason. Here they are:
    They have great forward visibility (LED powered like Jack was referencing) and rear facing indicators in the mirror that both add to the rear facing turn signals on the trike body and are obvious to the rider that the turn signal is flashing. To MDO's point, my local HD dealer was consulted and it was not a problem to install these on the Trike (mine is a 17 Freewheeler) stock front end or otherwise.
    Just an idea, If you want a pair, I have a brand new set that I am now not going to use. So I can make you a deal on them.
    Aug 2018
    LAS VEGAS
    Decided to try these leds. No drilling, just tapped into turn signals. Going for a ride, see how they work. Would like them a little higher on nacelle, but this was quick and easy.
    Mar 2018
    Saint Louis
    Looks good and bright
    Oct 2017
    St. Louis, MO USA
    They look great. My toggle switch for my HD Cool-Flo fan is in the spot where your right one is.
    Aug 2018
    LAS VEGAS
    Sorry about the sideways picture.Moved my indicator lights one last time. these work perfect now. do not have to move my head down to see, just look down with my eyes.
    1500+ Posts ShapeShifter's Avatar
    Aug 2018
    SW, Arkansas, USA
    Cool Nice!!
    ....I like that Temp Gauge to the left too.
    2016 Tri Glide Billet Silver w/Pinstripes ["Hi-Yo, Silver! Away!"]
    • "There is so much good in the worst of us, and so much bad in the best of us, that it ill behooves any of us to find fault with the rest of us." ..... James Truslow Adams
    • 2nd BN 33rd Armor "The Tiger Battalion" "1972 - 1974"
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    I like those lites... Where did you find them ?? All I have found so far are grouped
    Aug 2018
    LAS VEGAS
    Found them on Amazon. Google indicator lights and click on Amazon. These are 5/16 inch hole diameter lights. Alpinetech 12 volt. $ 6.00 Each.
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Thanks. Was everywhere but Amazon lolol
  19. #19
    90+ Posts Saammi's Avatar
    Jun 2018
    CT, USA
    NICE
    “Knowledge is knowing that a tomato is a fruit, wisdom is not putting it in a fruit salad.” ...Gene Takovic
  1. Dashboard gear indicator/no lights??
    By maestro319 in forum Honda Trikes
    Last Post: 04-08-2014, 05:18 PM
  2. dash lights
    By trikeleader in forum Stallion Trikes
    Last Post: 05-09-2013, 08:01 PM
  3. Stallion dash lights
    By Dwayneaevans in forum Stallion Trikes
    Last Post: 03-14-2012, 02:15 AM
  4. Dash lights
    By Dwayneaevans in forum General Discussion
    Last Post: 02-16-2012, 12:00 AM
  5. Dash lights...
    By pmar6004 in forum Stallion Trikes
    Last Post: 06-20-2011, 09:26 PM
