ctdair7Jack KlarichHarley Tri GlideHot Rotors After New Pads
Speed Bleeders
Likes Likes:  0
Thanks Thanks:  2
Results 1 to 14 of 14
Thread: stallion ac/heat blower motor
    40+ Posts
    Mar 2019
    Myrtle Beach
    Default stallion ac/heat blower motor
    any one know where to get ac/heat blower motor mine is not working on hi ty
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Quote Originally Posted by Just BOB View Post
    Check and make sure its not the switch first.
    40+ Posts
    Mar 2019
    Myrtle Beach
    Default switch
    Quote Originally Posted by Gorilla View Post
    ok ty is the switch hard to get out
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    I've never actually taken it out so not sure but it doesn't look that bad.
    200+ Posts
    Feb 2017
    Arp, TX - USA
    Before you spend too much time.. What year is the Stallion & is the fuse box in the engine compartment more rectangular & look just like the one in the owners manual, or is it a smaller square shaped fuse box?
  6. #6
    40+ Posts
    Mar 2019
    Myrtle Beach
    Default blower motor
    Quote Originally Posted by trike tech View Post
    its a 2009 I haven't check the fuse it blows fine on low and med don't blow on hi
  7. #7
    2250+ Posts radismukes's Avatar
    May 2018
    Angleton, Texas
    Check this Youtube video
    Hope it helps
    “Come and Take It!” “Remember the Alamo!” “Remember Goliad!”
  8. #8
    300+ Posts
    Apr 2011
    Signal Mountain Tn
    If you end up replacing the switch, it is not that difficult to remove. It is easier if you pop that whole panel out first which has heater controls and radio I believe. You can pull the plug a loose on the back of the panel to give it a little more freedom. On the small panel with the heater/ac controls it has a backing plate held on by 2 small screws. Remove the screws and it all comes apart. When you get it apart, you can see the small allen screws on the knobs. This is a good time to tighten them as they tend to work loose. Last time I worked on mine about three years ago, I applied locktite to the allen screws and had no more trouble.
  9. #9
    200+ Posts
    Feb 2017
    Arp, TX - USA
    If it's an 09 you probably have the rectangular style box (but verify to be sure, it does matter!). If it works on low/med but not high it's most likely the fan relay going out & causing your issue, but to reiterate this is ONLY for the rectangular fuse box. Low/med bypasses the relay, but the high side goes through the relay because of the draw it creates. It's a regular automotive relay that can be had @ any parts store.
    fan/ac relays are located right beside the riders backrest bracket & should be zip tied to the underside of the frame rail (unless they've been moved or messed with). There are 3 relays & the outer relay that has an orange wire going to it is for the high side fan control. I'd check the relay first, it's be far the easiest to get to & with the fan/switch controls on the dash no longer being available it's your best hope also.
    Also for future reference in case you were unaware, the center relay is the one that provides power to the cooling fan for the radiator also.
  10. #10
    40+ Posts
    Mar 2019
    Myrtle Beach
    Default fan switch
    would like and thank you for all your help when I get time this week ill check it out and ty again
  11. #11
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Richard what does the 3rd relay do?
  12. #12
    200+ Posts
    Feb 2017
    Arp, TX - USA
    3rd one (or 1st depending on how you view it) is the power relay. It ties the fan, heat & a/c relays to the system power for operation.
  13. #13
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    thank you
  14. #14
    40+ Posts
    Mar 2019
    Myrtle Beach
    Default ac/blower motor
    I got time and checked the relay you told me about got a new one it works fine on all three speeds thanks again for your help here is part # R3177 BWD brand got it advance thanks again
  1. Blower Motor Switch Issue
    By Heart Stoppper in forum Stallion Trikes
    Last Post: 11-19-2015, 10:41 PM
  2. SMALL LEAF BLOWER (2 cycle)
    By Baldy_54 in forum General Discussion
    Last Post: 12-01-2013, 04:28 PM
  3. Engine - Turbo or Blower???
    By Ellard in forum Harley Trike Conversions
    Last Post: 09-04-2013, 09:50 PM
  4. Blower VS Turbo
    Last Post: 02-27-2012, 04:49 PM
  5. New Motor Trike/Stallion Dealer in Daytona
    By Gorilla in forum Stallion Trikes
    Last Post: 10-16-2010, 07:21 PM
