Likes Likes:  2
Thanks Thanks:  1
Results 1 to 5 of 5
Thread: 01 Goldwing Lehman monarch 1 Rear end grinding noise
    Aug 2018
    Tacoma
    Default 01 Goldwing Lehman monarch 1 Rear end grinding noise
    Front driveshaft U-joint exploded. Had to drive another 10 miles to get to a place where I could be towed. Now, while getting there the rear end made and still does make a grinding - pause- grinding while under power. No grinding when in going thru the gears while on the stands. Only when on the road and power is put to the rear end. Drive shaft tunnel ( ?) is largely un-scarred. So it's not coming in contact with the drive shaft. Pulled the diff. cover. Results.... 12 to 18 extremely tiny sparkles, oil smelled like new and un-burnt. Very little gear slap at the drive shaft diff. connection. Had pick ups with a lot more gear slap and a lot more miles did fine.
    I'm no M/C mechanic but if someone would please point me in the right direction I'll make the repair. Many Thanks to all of you.
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by Tang62 View Post
    Scott, If you are available I can call you at home about your dilemma . Jim
    respond back here
    Jim Murphy
    Iron Butt Rider 2001
    Aug 2018
    Tacoma
    respond back here
    Thank You. At home now.
    60+ Posts
    Apr 2016
    Monroe, NC , Union
    Hello Tang62,
    Can you keep us in loop on your grinding noise? Thanks,
    Martinsburg, WV
    Quote Originally Posted by camplejeune View Post
    Hello Tang62,
    I don't recall the specific conversation and the OP has made no other posts since 2019 ??
    Jim Murphy
  1. 2002 GoldWing Lehman trike Monarch ll, brake shoes
    By Thomas Berry in forum Lehman Trike
    Last Post: 03-14-2019, 07:10 AM
  2. 2015 goldwing lehman monarch ii auxiliary rear shock
    By MAMPORRERO in forum Lehman Trike
    Last Post: 09-15-2018, 08:12 PM
  3. Grinding noise in reverse
    By Lazycats in forum Harley Freewheeler / Road Glide 3
    Last Post: 07-05-2016, 09:11 AM
