Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  12
Thanks Thanks:  1
Page 2 of 2 FirstFirst 1 2
Results 21 to 27 of 27
Thread: Battery Replacement
  1. #21
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by hocnsoc View Post
    Just bought a used bike with new lithium ion battery. Left the ignition switch on accessory by accident. Now battery is at 0.85 V and the special LI battery tender will not bring it back up. Not going to buy a lithium ion charger just for this. Will put it on a 2A charger for a while and see if it will come up to a range where the tender can read the voltage and continue from there. You have to be careful with these batteries. I think these batteries are more trouble than they are worth.
    I agree......And you might want to [Try to] charge that battery out of the trike using a regular charger......
    2019 Tri-Glide.......
  2. #22
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    You can use a lead-acid charger to charge lithium batteries as long as you can set the maximum voltage of the charger and as long as the charger does not have an automatic equalization mode enabled.
    HOW CAN YOU HELP THE TRIKE TALK FORUM? Become a GOLD CLUB MEMBER!
    A veteran - whether active duty, retired, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to the 'United States of America', for an amount of 'up to and including my life.'
  3. #23
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Some lead acid chargers “ping” the battery on startup to determine the voltage/resistance of the battery. Based on return information, the charger then determines what charge phase to start in. Because lithium will hold voltage above 13+v, some lead acid chargers will see this as a near full battery and enter into a float stage and bypass the charge stage all together.
    If you want to use a lead acid charger on a lithium battery you can, HOWEVER, you must NOT use a lead-acid charger if it has an automatic “equalisation mode”, which cannot be permanently turned off. A lead-acid charger that can be set to charge no higher than 14.6v can be used for regular charging and then MUST be disconnected after the battery is fully charged. DO NOT leave the lead-acid charger connected to maintain or store the battery, because most will NOT maintain the proper voltage charge algorithm for lithium batteries and damage will occur to the battery and this is not covered under battery warranty.
  4. #24
    1000+ Posts Texan's Avatar
    Jun 2013
    Texas
    Default Just replaced mine on my '13
    You never know about batteries. Now that you've started talking about it it'll probably go bad.
    I have 26,000 on my clock and WAS planning to dead to Sturgis and thought it would be a good time to change it out. Didn't want to be in the middle of Nebraska and it take a crap on me. I might add my bike is on a Battery Tender Plus every night, since the day I brought it home except when I'm on the road.
    I got mine off Amazon for around $129.00 with a 2 yr warranty.
    8~\o
    "Anybody can become an American but ya have to be born a TEXAN"
    "Ya know I haven't been everywhere but it's on my bucket list"
  5. #25
    150+ Posts KJB's Avatar
    Oct 2014
    NE WI & SW FL
    My 2015 has the original battery and I was planning to replace it when I return to WI from FL next spring. However, I do notice some hesitation when starting so I think I'll bite the bullet now and replace it. Still have more riding planned before we head to FL in October. I'll probably just let the dealer replace it with the OEM battery since the original one has served me well.
  6. DKCustoms postbit
  7. #26
    250+ Posts
    Nov 2012
    Bradenton, FL.
    2019 Red and Silver Tri Glide
  8. #27
    40+ Posts Al Corr's Avatar
    Jun 2020
    New Bedford, MA
    My 2016 had the original battery and I just replaced it at the Dealer, with a stock battery. I always keep it pluged in to a battery tender. Works for me.
  1. Battery life and battery purchase
    By pcombe in forum Harley Trike Conversions
    Last Post: 02-21-2019, 05:53 PM
  2. Replacement Battery
    By Sunman in forum Harley Freewheeler / Road Glide 3
    Last Post: 09-15-2018, 08:57 PM
  3. Replacement Battery
    By Sully in forum Harley Tri Glide
    Last Post: 08-24-2018, 08:39 PM
  4. Battery Replacement
    By Snipe in forum Harley Tri Glide
    Last Post: 06-05-2017, 03:01 PM
  5. Battery Status & Replacement
    By Muleskinner in forum General Discussion
    Last Post: 03-17-2011, 10:51 AM
