Hello all, I recently installed a Kuryakyn batwing fairing pouch and Klock Werks windshield on my 18 tri-glide. I now have gap at the top of my fairing on each side of the windshield. Any suggestions on how to alleviate this problem?
Brian
Brian
Brian , I can't help you with your problem, But i can Welcome you To Trike-Talk....
I'm sure someone will chime in soon with some ideas...
Hi Brian, Welcome aboard. I'm trying to visualize.....Did it only occur after you installed the pouch? Instruction do require removal of the stock middle screw and replacing it with the screw and washer provided with the pouch. Then torque all screws based on install instructions.
2016 Tri Glide Billet Silver w/Pinstripes ["Hi-Yo, Silver! Away!"]
• "There is so much good in the worst of us, and so much bad in the best of us, that it ill behooves any of us to find fault with the rest of us." ..... James Truslow Adams
• 2nd BN 33rd Armor "The Tiger Battalion" "1972 - 1974"
If I recall correctly, many of Klockwerks are kind of oddball shaped (not saying they don't work well at keeping the wind off), and this may account for the gaps. They may not be there if you have a regular curved windshield.
AND...Welcome to Trike Talk from eastern Kentucky!
Welcome to the Gang from Western Colorado.
Just visualizing this ... if you "over tightened" the windshield screws you may have pulled the brass inserts out some from the plastic ... this brass sticking out might be keeping the outer faring from sitting flush ... don't ask me how I know about this ... ... the fix is fairly simple ... i put couple drops of adhesive on the side of the insert, a tongue depressor on the inner faring and used a pump plier to gentle squeeze between the brass insert and the tongue depressor until the brass insert was back in place ... let the glue cure ... put it back together.
I have the same issue after installing a thicker Freedom Shield and the HD windshield pouch. You only see it at the top outside edge of the bat wing if it's what I think you're talking about.
It's normal, not much you can do about it. You are the only one apt to see it anyway...
I thought about a small bead of clear silicone but I didn't. Doesn't bother me anymore.
Happy motoring!
That has been my experience on my 16 TGU also. Small opening left on each side , but very small. If you tighten them too much, as stated above, you can pull out the brass insert or cause the windshield to crack in the area where the screws go.
The same applies to the screws that secure the inner fairing to the outer, you tighten them too much and you will pull out the brass fittings.
