Likes Likes:  4
Thanks Thanks:  7
Results 1 to 6 of 6
Thread: A Quick & Easy Cruise Control Diagnostic Check-No Tools Required!
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Default A Quick & Easy Cruise Control Diagnostic Check-No Tools Required!
    I learned a nice & easy way to test your cruise control circuit. I will link to a video at the end.
    1. Make sure your kill switch is off.
    2. Turn on your ignition switch.
    3. Push your CC switch in to activate the amber speedo indicator.
    4. Hold down your CC switch like you would to set it & flip the kill switch to run.
    Your CC indicator will be amber & when you engage your clutch, front or rear brake or roll your throttle forward, the indicator light changes to green, signaling that that switch is functioning properly and all is well. I tested it on my 2017 Freewheeler & it worked great
    Very cool.
    https://www.fixmyhog.com/video/harle...mp;vsoid=A6136
    Oct 2017
    St. Louis, MO USA
    I forgot to mentioned this should work on all touring models & both trikes.
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Cool.Wouldn't the BCM throw a code during self diagnostic when the ignition switch is turned on if there was a fault in the cruise control switch/circuit?
    150+ Posts riden2low's Avatar
    Sep 2013
    Otis OR
    Thanks guys I will try that.
    2014 Triglide
    Fullsac Headers
    V&H Deluxe mufflers
    Fuelpac FP3
    S&S Airstream Slealth A/C
    Anarchy 5 Spoke wheels
    200+ Posts
    Nov 2016
    groesbeck texas usa
    My 16 is doing the same thing when I ran the codes it came up rear brake light switch and BCM. Bought the switch then changed my mind as to change it the entire exhaust has to be removed.
    40+ Posts
    Aug 2019
    Ocala FL USA
    Very cool.
    Yes it was one of the first things I did but thanks for sending your post.
  1. Cruise control problem
    By lamornawing in forum Honda Trikes
    Last Post: 03-26-2023, 02:48 PM
  2. Check Valve Required
    By Lawingnutz in forum Honda Trikes
    Last Post: 02-23-2015, 09:44 PM
  3. Eat broccoli & get a free cruise control!
    By Dante221 in forum Harley Trike Conversions
    Last Post: 08-21-2011, 03:40 PM
  4. No brake lights...no cruise control
    By ODDOMAN in forum Stallion Trikes
    Last Post: 09-24-2010, 11:38 PM
  5. cruise control issue
    By cowboy in forum General Discussion
    Last Post: 04-07-2008, 05:04 PM
