14TG114TGHarley Tri GlideInstallation of a new Fuel Filter &...
BigN693GorillaEnabled TrikersFull length floorboards
Likes Likes:  6
Results 1 to 9 of 9
Thread: no rear brakes on 2011 Vision Crossbow rear end.
    Jan 2019
    Lenexa, ks
    Default no rear brakes on 2011 Vision Crossbow rear end.
    Trike has set since early Nov. I put new tires on it and was taking it out, when I smashed the rear brakes there were none.. I pumped them and it started to build up pressure. I got home and had a friend help me bleed them. nothing seem to work. We noticed I left the E-brake on. I release it and we bleed the middle bleeder on the front brakes and when I started pumping the rear brake it went to the floor with no pressure and none would build up. We started over and the same. Any Ideas????
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Cool Victory Vision Crossbow Brake Bleeding Sequence
    BRAKE BLEEDING
    Note: Before the brake bleeding process begins, make sure that the piston moves out so there is no clearance between the pads and rotor. Otherwise bleeding will not be achievable.
    1. Fill brake fluid reservoir with DOT4 brake fluid.
    2. Massage the reservoir hose to remove any air that may be present in it.
    3. Attach brake bleeder to the first bleeder (right rear caliper) screw as shown making sure to install the 10mm wrench to the bleed screw first.
    4. Suck out all air from brake line with the brake bleeder until fluid begins to come through by turning on the brake bleeder and opening the bleeder screw slightly.
    5. Tighten the bleeder screw and remove the brake bleeder and 10mm wrench.
    Note: Be sure to keep an eye on the fluid level in the reservoir so as to not introduce any more air into the system.
    6. Repeat steps 1-5 on the remaining bleeder screw using the proper sequence.
    7. Again, Attach 10mm wrench and brake bleeder to bleeder screw.
    8. SLOWLY and EVENLY pump the brake pedal 7-8 times and hold the pedal down after the last pump. (an additional helper is required for these next few steps)
    9. With the brake pedal held down, open the bleeder screw with a 10mm wrench. Bubbles will surface into the brake bleeder hose.
    10. Close the bleeder screw with a 10mm wrench.
    11. Turn on the brake bleeder to suck up any fluid that may have collected in the hose.
    12. Repeat steps 7-11 for each bleeder screw until no bubbles emerge from the brake system. This includes tiny bubbles as well as large.
    13. (not a typo) Repeat steps 7-11 to bleed the front brake calipers until no bubbles emerge from the brake system. This includes tiny bubbles as well as large.
    14. Fill reservoir with brake fluid to within 1/8” from the top.
    15. Install M10 x 35 Bolts to the bottom mounting holes of each caliper using loctite 243 with spacers in place. Tighten using 14mm socket.(2) M10 x 35 Bolt (CB1995)
    16. Torque and mark caliper bolts to 35 ft-lbs using 14mm socket.
    Jim Murphy
    Iron Butt Rider 2001
    Jan 2019
    Lenexa, ks
    Default how to move the piston
    Thanks Lee for the info!!
    One question, can you clamp the pads together or move the pistons with a 'C' clamp?? Or what do you use to move the piston?
    Martinsburg, WV
    Cool
    Quote Originally Posted by Buellee View Post
    Jim Murphy
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    If that is the style rear caliper with the e brake built in. Once the piston is fully retracted, do not apply the e brake until the the pads are pumped out against the rotor. If you don't you can have a low pedal condition
    Jan 2019
    Lenexa, ks
    Lee
    I could of done that, how can i get around that??
    Thanks for the info.
    I pumped the right rear and got both fluid and bubbles. now no fluid is coming out. So my thought is to reverse bleed, from the bleeder valve to the reservoir.Any thoughts on that??
    Martinsburg, WV
    Cool
    Lee
    Get around 'what' ??
    If the master cylinder is not transferring fluid, it wouldn't matter if you filled from the bleeder, it still wouldn't make pressure.
    Have you bled the master cylinder ???
    Perhaps a phone call would clear these things up. www.mjtrikes.com
    Jim Murphy
    Start @ the master cylinder
    Bench bleed it, if it has gone South you will never bleed the air out @ the calipers
    Look in the cylinder as you slowly pump, do you see bubbles coming out thru the compensator port? If you do not you are not going to build pressure
    Use slow and even strokes when bleeding, try not to go full to the bottom of the bore. This can cause a seal to roll over, bad Ju Ju
    You can also try a bench bleeding kit like this
    Available from an auto parts store
    Jan 2019
    Lenexa, ks
    Default Thanks for all the info on the brakes
    Jim it was great talking to you..I tried bleeding the master cylinder as told but more brake fluid on the floor than in the unit. Shortly I got a phone call from another old biker. He told me that the Old Polaris dealer that had both The Indian and Victory mechanics were still working for them. I called them and they knew what was wrong. The mechanic that worked on the brakes was there when I picked it up the next day. He said that Lehman removed the ABS brakes from the rear wheels, but left the blocking valve intact to the front brakes. They had to energize the blocking valve to bleed the brakes. They also said if the master cylinder needed to be pumped up later this season, then a master cylinder kit or new cylinder would be needed. Again, thanks to everybody and the info I received.. I should of responded earlier, but what the heck.. I was ridin in the wind.
    Tom
  1. Photos of your rear end —. Not THAT rear end !!!!!!
    By Snickers1948 in forum Harley Tri Glide
    Last Post: 11-04-2017, 02:07 PM
  2. Rear brakes on 2011 Tri-glide
    By Finn in forum Harley Tri Glide
    Last Post: 05-16-2017, 03:10 PM
  3. Lehman Trikes CrossBow now available for 2014 Victory Vision!
    By Trike Talk News in forum Victory Trikes
    Last Post: 05-21-2014, 02:55 PM
