Phu Cat3cScjhbGeneral DiscussionIs there a TV commercial
Phu Cat3trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat3Phu CatGeneral DiscussionIs there a TV commercial
Likes Likes:  2
Thanks Thanks:  1
Results 1 to 4 of 4
Thread: LED"s
    60+ Posts
    Jan 2018
    Milton Mills NH
    Default LED"s
    I know I have seen a thread on this but......
    How does one slow the blinkers down after installing LED's? The bike is a 2016, replaced the directions with Custom Dynamics and led bulbs in the rear.
    Thanks guys.
    From Their Web Page
    Custom Dynamics® Technical BulletinTurn Signal Sync on H-D BCM ModelsQuestions? Call us at: 1 (800) 382-1388 M-TH 8:30AM-5:30PM / FR 9:30AM-5:30PM EST07-2016TECHSome Harley-Davidson models equipped with canbus/BCM electrical systems while installing Custom Dynamics® LED turn signals in place of incandescent bulbs, will need to per-form a turn signal sync so that the product will function properly with the system.1.Turn Ignition on, but do not start the bike.2.Turn on 4 way hazards by pressing the hazard button on the controls. Turn Signal Sync Procedure3.Turn the Ignition off letting hazards run. IF the bike has security they will flash 5 or 6 times and then pause. This is normal. They will go back to flashing normal hazard mode.4.Let hazards run 1-2 minutes.5.Turn Ignition back on.6.Turn off hazards.7.Turn Ignition off and then back on.8.Check function of both turn signals.Note: Follow the instruction above. DO NOT press both turn signal switch's at the same time. That is the way the hazards activate on PRECANBUS bikes.
    100+ Posts
    Sep 2016
    Sitka, Alaska USA
    Get a blinker that works off a timer rather than off of a load. There are many brands made for led applications. Mine was about $12 from eBay.
    60+ Posts
    Jan 2018
    Milton Mills NH
    From Their Web Page
    Thank you, I will try that, if no success I will look for a flasher.
  1. Replies: 5
    Last Post: 09-06-2015, 05:11 PM
  2. Replies: 3
    Last Post: 04-03-2013, 03:11 AM
  3. Kawasaki Vulcan 1500 "A" or "B" trike kits ?
    By geokoppmann in forum Suzuki - Kawasaki Trikes
    Last Post: 12-24-2012, 10:22 AM
  4. Tellico Cafe..."Pattymelt"..."Pics".....
    Last Post: 10-05-2010, 11:41 AM
  5. Braking..."TO" or "NOT TO"
    Last Post: 08-06-2010, 04:42 PM
