ADSavarese8ol' schoolNew Member Introduct...New member from FL
ADSavarese8GorillaNew Member Introduct...New member from FL
ADSavarese8Marc HNew Member Introduct...New member from FL
ADSavarese8ADSavareseNew Member Introduct...New member from FL
ADSavarese8Phu CatNew Member Introduct...New member from FL
ADSavarese8trike ladyNew Member Introduct...New member from FL
ADSavarese8Uncle FesterNew Member Introduct...New member from FL
ADSavarese8rhino 2New Member Introduct...New member from FL
Likes Likes:  11
Thanks Thanks:  2
Results 1 to 20 of 22
Thread: 2018 front brake bleed
    30+ Posts
    Mar 2018
    VALE NC
    Default 2018 front brake bleed
    hi wondering the right way to bleed front brakes on tri glide
    thanks gabe
    200+ Posts
    Sep 2018
    Pa
    Default Brake bleeding
    According to 2015 trike supplement bleeding sequence is:
    Front- left - 4 oz.
    Front-right- 2 oz.
    If you continue to do rear brakes :
    Front - left (lower bleeder) - 2 oz.
    Front - right (lower bleeder) - 4 oz.
    Rear left - 4 oz
    Rear right - 2 oz
    ** Torque specs :brake caliper bleeder valve front: 80-100 INCH lbs
    brake caliper bleeder valve rear : 31-33 INCH lbs
    Rear bleeder valves are much smaller than front.
    ******** This is for a NON-ABS SYSTEM**** Best to check with someone who knows if abs front is same otherwise you may cause damage to system??!
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Quote Originally Posted by 7125 View Post
    thanks gabe
    Gabe, you really need to get a service manual. It will help you in answering numerous service questions.
    Well worth the small cost. I got 1 for my Freewheeler in PDF format & I love it.
    You can print out what you need for a particular service and even load it on a tablet.
    200+ Posts
    Sep 2018
    Pa
    Default PDF
    shaker
    I've checked the numerous sites for downloading, listed on several forums. Maybe it's just me, but it appears Harley has taken away access to their bikes/trikes
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    TGs didn't get ABS until 2019 model year.
    30+ Posts
    Mar 2018
    VALE NC
    Quote Originally Posted by ultrafxr View Post
    true do you use the top or bottom bleeder
    thanks
    200+ Posts
    Sep 2018
    Pa
    Default Sequence
    thanks
    What i had posted earlier is taken verbatim from the manual. The top bleeder is for the front.
    The numbers are the amounts of fluid you should draw from each bleeder.
    Then the sequence indicates the lower (bottom) bleeders are connected to the rear master cylinder.
    If only doing front brakes and front master cylinder use upper/top bleeders
    30+ Posts
    Mar 2018
    VALE NC
    Quote Originally Posted by Tucci View Post
    thank you ever much
    gabe
    Oct 2017
    St. Louis, MO USA
    shaker
    I noticed they were removed from the site I got mine from, Service Manual Warehouse.
    Jack had mentioned a site a few weeks back, but I can't locate it.
  11. #10
    200+ Posts
    Sep 2018
    Pa
    Default Pdf
    When you initially posted the site addresss, i checked it out and all Harley manuals were offered for purchase. About 2 weeks later when i finally decide to purchase one, they were taken down.
  12. #11
    200+ Posts
    Sep 2018
    Pa
    Default Bleed front
    thank you ever much
    gabe
    Use a torque wrench to tighten. Remember, bleeders are virtually hollow tubes and can and will twist or break off. And are a pain to drill out.
    I know a thing or two, because I've done a thing or two😮
  13. #12
    https://harley.manuals.cc/search/?q=...max-results=50
    Try here, this site updates frequently
  14. #13
    If you don't have an inch pound torque wrench, just snug em good
    Like Tucci said they can and will break
  15. #14
    Tru Dat ... don't ask how I know ... LOL
  16. #15
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    There are two bleeders per caliper - upper for the front brake and lower for the rear brake. Been that way since the reflex linked brakes were introduced in MY2014.
    The problem I'm seeing is that the bleeder screws are inboard of the caliper. I can't see how to get a wrench on them to loosen and tighten. If anyone has done it or knows how a service technician does it please let me know. I'm thinking the caliper would have to be removed from the fork and bled off the bike.
  17. DKCustoms postbit
  18. #16
    Jerry, I just did my 17 Freewheeler front linked brakes, I used a wrench like this with no problems
    I always crack the bleeders loose before taking the calipers off
    I really don't like the plastic brake lines much, make sure to support the caliper when removing it for pad removal
  19. #17
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Thanks for the info Jack. Still a bit confused. Did you have to remove the calipers from the fork in order to bleed them?
  20. #18
    I did not
  21. #19
    Oct 2017
    St. Louis, MO USA
    I bled the front circuit of my 2017 Freewheeler, like Jack stated & I didn't remove the calipers. Do the left side 1st, then the right. It's not hard, but I use an in-line check valve right off the tubing that goes on the bleed screw. It keeps air from re-entering the brake circuit. The check valve was made by Motion-Pro, I believe. It was around $10
  22. #20
    1 word of caution when working on the front linked brakes
    Be careful when removing the calipers
    Unlike brakes from before, these calipers have hard plastic lines instead of the rubber ones you may be used to seeing
    They are not as forgiving, support the caliper at all times, do not let them hang free
  1. Rear Brake Flush/Bleed on CSC Trike
    By rhino65 in forum Honda Trikes
    Last Post: 06-08-2019, 11:20 AM
  2. Champion front brake bleed question
    By scribe5 in forum Honda Trikes
    Last Post: 01-27-2014, 01:18 PM
  3. Champion trike rear brake bleed advice
    Last Post: 01-20-2014, 05:00 PM
  4. Adjusting lid and bleed brakes on Hannigan
    By gr8phun in forum Honda Trikes
    Last Post: 01-21-2013, 03:46 PM
