Phu Cat2trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat2Phu CatGeneral DiscussionIs there a TV commercial
Likes Likes:  10
Thanks Thanks:  1
Page 2 of 2 FirstFirst 1 2
Results 21 to 35 of 35
Thread: Motor Trike not reputable IMO
  1. #21
    150+ Posts
    Jun 2017
    Asheville,NC USA
    I will double check, but, I am almost positive they are steel.
  2. #22
    100+ Posts
    Apr 2019
    Lewisville
    Highly unlikely the sprockets are anything other than steel .
    Look carefully at both sprockets , look for any teeth that have a sharp edge or a sign of more wear on one side than the other. Check the spacing on the teeth and the depth of the teeth at their lowest point.
    I suspect the sprockets are not aligned properly. This will cause very rapid wear of both the chain and the sprockets. A clear sign is a hook at the top of the teeth. Is the chain binding at it's loosest point or at it's tightest point ?
    Normally at the loosest point on a two wheeled bike the chain flex is about 1/2 to maybe 3/4 inch.
    Modern chains are sealed units that have internal lubrication at each link. Cleaning them really only removes the outer crud, check with the chain manufacturer about what type of solvents they recommend.
    How best to align the sprockets should be addressed by the trike maker/installer.
    I know how to do it on a motorcycle , but not on a trike ,Yet.
  3. #23
    Chains do stretch .....So they do need routine adjustments....With my ATC's ATV's when i would run out of adjustments.....[Now i wouldn't do this with a street bike.]..But i would knock a link out of the chain to shorten it...
  4. #24
    Jun 2008
    Lovington, NM, U.S.A.
    I visited a website of a company that makes motorcycle sprockets and they do make aluminum ones but they are used primarily for racing applications. http://www.rebelgears.com/officialrebelgearshome.html On another site they did list that a steel sprocket should last between 10,000 and 30,000 miles before replacing.
    You can read that here: https://www.solomotoparts.com/blog/A...ycle-Sprockets
    Retired trike builder
  5. #25
    Apr 2010
    Shenandoah Valley of Virginia
    My Triumps had steel transmission sprockets and aluminum larger rear sprockets, My Norton was steel at each end. Used roller chain and often pulled chain off with old one to leave in place to pull good one back on weith, thourough cleaning in kerosene, then I'd hang it by a wire, slather Marfak grease on it and heat with a propane torch just enough to see Marfak drawn into rollers & links at pins … let cool and reinstall and adjust.
    Later years, when it got harder to find Marfak, I used spray on chain wax which was applied to warm chain. Was easier to apply on bike after warm up ride, but still pulled chain off for good cleaning.
    Now, they use O-ring chains that are fatter and can chew into trans housing in places, but there is no cleaning, just use lube meant for O-ring chain I'm told.
  6. #26
    150+ Posts
    Jun 2017
    Asheville,NC USA
    Thank you all for your comments, I will definitely check old parts to check wear and or breakage.
  7. #27
    100+ Posts
    Apr 2019
    Lewisville
    Quote Originally Posted by Pastor Ron View Post
    Please keep us informed as you progress through this project. I see from your home page (( or what ever it's called) that you are in Ashville, NC . I'm a couple hours east of you in Lewisville, NC. maybe we can arrange to meet up and I could look at your machine. Sounds interesting , what ever the problem is.
  8. #28
    150+ Posts
    Jun 2017
    Asheville,NC USA
    Sounds good to me, whenever I get it back ( still waiting on parts to arrive ), I will give you a shout and try and hook up. THANKS !
  9. #29
    150+ Posts
    Jun 2017
    Asheville,NC USA
    Default Get in touch
    Quote Originally Posted by Douglas44 View Post
    Douglas, Donna and I will be out your way tomorrow 4/24/19; if you want to meet up and look at my GT3 and/or old parts give me a call at H- 828-367-2142 or cell 828-275-0215. Thanks, Ron
  10. #30
    150+ Posts
    Jun 2017
    Asheville,NC USA
    It turns out when all is said and done, the combination of cleaning with kerosene and lubing with teflon lube, was the worst thing I could have done. It caused premature wear of chain, which caused premature wear of front sprocket. THIS WAS MY FAULT NOT MOTOR TRIKE. Some (so CALLED experts on YouTube), advised this was a good thing to do, in MY case. It was not. I learned a very valuable (and expensive) lesson.
  11. #31
    Default Motor Trike IS reputable
    Good to know that there is a reason other than "normal wear and tear" ... sorry you learned the hard way ... most lessons, unfortunately, are hard learned.
  12. #32
    May 2018
    Angleton, Texas
    Glad to hear you were able to find the reason for the failure. We've all been there and done that at some point. Ride safe and more miles of smiles!
    Robert
  13. #33
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Cool
    Imagine that, FAKE EXPERTS on the internet !!!! I am perplexed !!
    Jim Murphy
    Iron Butt Rider 2001
  14. #34
    1500+ Posts ShapeShifter's Avatar
    Aug 2018
    SW, Arkansas, USA
    Thumbs up Motor Trike Is Vindicated!
    Thanks for providing the updated details.
    2016 Tri Glide Billet Silver w/Pinstripes ["Hi-Yo, Silver! Away!"]
    • "There is so much good in the worst of us, and so much bad in the best of us, that it ill behooves any of us to find fault with the rest of us." ..... James Truslow Adams
    • 2nd BN 33rd Armor "The Tiger Battalion" "1972 - 1974"
  15. #35
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    Thanks for setting the record straight
    1989 GL1500 Goldwing (SOLD)
    2006 GL1800 CSC
  1. Replies: 12
    Last Post: 04-16-2019, 01:56 PM
  2. Vtx1300 Motor Trike not level
    By True1shot in forum Honda Trikes
    Last Post: 01-28-2014, 06:20 PM
  3. Replies: 4
    Last Post: 03-01-2013, 01:18 PM
  4. Replies: 0
    Last Post: 02-28-2013, 07:32 PM
  5. GW and Motor Trike raked neck or not??
    By JaysGone in forum Motor Trike
    Last Post: 11-23-2012, 10:05 AM
