ADSavarese6Marc HNew Member Introduct...New member from FL
ADSavarese6ADSavareseNew Member Introduct...New member from FL
ADSavarese6Phu CatNew Member Introduct...New member from FL
ADSavarese6trike ladyNew Member Introduct...New member from FL
ADSavarese6Uncle FesterNew Member Introduct...New member from FL
ADSavarese6rhino 2New Member Introduct...New member from FL
Results 1 to 5 of 5
Thread: what size is the air hose line on SA motortrike kits ?? i need fittings
    20+ Posts
    Apr 2019
    new orleans, la, usa
    Default what size is the air hose line on SA motortrike kits ?? i need fittings
    I'm ordering new air bags from airbagit and I need to know what size the air line is. the fitting is evidently a 1/8" NPT, but I dont know the air line size. Anyone ?
    Cheers
    200+ Posts
    Feb 2017
    Arp, TX - USA
    1/8" air line all the way through... Unless someone replaced it with something of a different size (which almost never happens).
    20+ Posts
    Apr 2019
    Quote Originally Posted by trike tech View Post
    Well, that's odd. their website doesn't show a 1/8" NPT elbow for a 1/8" hose. smallest looks like a 1/4" hose. take a look at this...
    https://www.airbagit.com/SearchResul...lbow+1%2F8+npt
    200+ Posts
    Feb 2017
    Arp, TX - USA
    If I had to make a wild guess, I'd say their stuff is used mostly for air ride cars & trucks which use 1/4 & up air lines (depending on application). A lot of their stuff is compression style which makes sense considering what it's used for primarily.
    May check out airlift since they make the majority of the airlift stuff used by MT. They might have the fittings in the right size.
    20+ Posts
    Apr 2019
    are the fittings push in type or compression ?
  1. ***DK Custom - New Line of Solo Seat Kits & Solo Seat Components***
    By DK Custom Products in forum DK Custom Products
    Last Post: 07-01-2019, 01:04 PM
  2. Zert Fittings
    By Fireeater in forum Roadsmith Trikes
    Owners Forum
    Last Post: 12-31-2017, 08:15 AM
  3. Transmission Vent Hose
    By trikermutha in forum Harley Trike Conversions
    Last Post: 01-08-2014, 04:07 AM
  4. Little Hose off Coolant Compartment
    By Will Parish in forum Harley Trike Conversions
    Last Post: 10-28-2013, 06:02 PM
  5. Vaklyrie Lower Radiator Hose
    By rmrc51 in forum Accessories
    Last Post: 10-27-2009, 12:17 PM
