Likes Likes:  22
Thanks Thanks:  16
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 51 of 51
Thread: 2019 triglide dtc
  1. #41
    10+ Posts
    Dec 2020
    Richmond Hill,Georgia,usa
    Well they worked with Harley Davidson master techs all day. They started from scratch everything's was checking good. The installed their test equipment on the bike and rode it. Well the 2287 code showed up and they were able to record it on the software recorder. So Harley Davidson is changing the software code and updating the dealers digital technician to load the change in the bike. Let's see what happens
  2. #42
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by Roy31320 View Post
    Makes me wonder how long before HD recalls ALL the 19, 20 and maybe the 21 models for software issues
    No bikes manufactured should keep having DTC come back and have a dealer say this is not a problem because HD does not have an answer other than throwing more parts at it. JMO
  3. #43
    70+ Posts
    Oct 2014
    kearney mo.
    or tell you to ride it till it breaks. I heard that a lot
  4. #44
    10+ Posts
    Dec 2020
    So today the dealership received the new code from Harley that was changed to fix the issue with the b2287 code. Like I said in my previous thread the Tech had his test equipment installed on the bike and recorded the code when it happened. So I was told Harley engineering fixed the problem in the code for the ABS Module. They flushed the ABS Module again and installed the the new software.
    The code was happening when I was stopping at stop signs or traffic lights. Applying front and Back brakes while down shifting. They rode the trike down town most of the day today through many stops and goes with no code. Hopefully they have found the problem and the the new software could help others with the same problems. They want to ride it one more time tomorrow then I'll pick it up. Hopefully this is the end to my problems. I let you know.
  5. #45
    10+ Posts
    Dec 2020
    Well got the trike back today. So they changed the software code and installed it in the BCM. Will follow up after a few rides
  6. DKCustoms postbit
  7. #46
    10+ Posts
    Dec 2020
    Default Code
    Well last Sunday I went for a 2 hour ride. Everything seem to be doing good. Half way through the ride I noticed the brakes felt funny. Well I got home and checked the codes. Well I had the following
    ECM U0121h. ECM not communicating with the ABS
    ECM U2067h
    BCM U0121h BCM not communicating with ABS
    BCM b2285h Rear Brake config
    SPDO U0121h. speedometer not communicating with the ABS
    so I took it back to the dealership. They called in a master tech. They replaced the ABS module. I test rode for 75 miles and the brakes felt like they did from the factory.
    So so bottom line the ABS module was failing and finally quit.
  8. #47
    70+ Posts
    Oct 2014
    kearney mo.
    Default codes
    ECM U2067h
    those codes i threw also they replaced the abs did the flash also. that was a year ago good luck
  9. #48
    10+ Posts
    Dec 2020
    Have you had any more problems?
  10. #49
    70+ Posts
    Oct 2014
    kearney mo.
    Default codes
    i hope i don't give myself bad luck but i checked the codes yesterday and didn't have any. Seems to be ok. I had it done last summer and have run a lot of miles and states since then. In florida now for the winter. Ride it like you stole it, have fun
  11. #50
    50+ Posts
    Dec 2020
    Hinesville, GA, USA
    Quote Originally Posted by TarheelLeo View Post
    I get b2285 all the time. Dealer checked it out and found nothing wrong. Battery good. If I keep it on battery tender I don't get the code. My opinion is it is a sensitive battery sensor. At the slightest drop in battery voltage it kicks out the code.
    That must explain the b2285 code intermittently showing on his triglide. I took it for a spin after I helped him install the suspension from 4Wheelonline onto his Wrangler. It runs smoothly. The dealer checked it twice and found nothing.
  12. #51
    10+ Posts
    Dec 2020
    So far so good. The abs module was the problem. 800 miles and no codes. Brakes are working like when it same from the factory. Thank God.
  1. Best heat reducing options and why for 2019 TriGlide?
    By HDDaddy7838 in forum Harley Tri Glide
    Last Post: 04-24-2019, 03:45 PM
  2. How to check DTC on Keyless 2018 and newer Harleys
    By Jack Klarich in forum General Harley Chat
    Last Post: 02-14-2019, 06:07 PM
  3. My 2019 Wicked Red/Barracuda Silver Triglide!
    By DDubya in forum Harley Tri Glide
    Last Post: 01-29-2019, 01:59 PM
  4. DTC Question
    By able2ride in forum Harley Trike Conversions
    Last Post: 10-16-2016, 07:13 AM
  5. Dtc p95pe?? Wtfo???
    By Nauga Mok in forum Harley Trike Conversions
    Last Post: 11-01-2013, 11:05 AM
