BigN693GorillaEnabled TrikersFull length floorboards
Likes Likes:  7
Thanks Thanks:  1
Results 1 to 16 of 16
Thread: Looking for recommendations for rear shock replacement
    5+ Posts
    Apr 2019
    Cumming, GA, USA
    Post Looking for recommendations for rear shock replacement
    Looking for wise council from y'all in regards to replacing my rear shocks.
    I have a 1996 GL1500A (purchased about a year ago). My right rear has bottomed out and my wheel is sitting on my fender. Shocks currently on my ride are Showa MAM L41. Ideally I want to move away from this setup as it appears the compressors is dead so would like to stay away from air shocks. In addition, looks like the last time the rears were replaced was back in 2010 (as that is the last entry I was able to find from the previous owner).
    I would greatly appreciate any recommendations about replacement shocks.
    As a side note, before the bottom out, my exhaust pipes only clear the ground by about 4"'s so needless to say speed bumps/humps haven't been my friend.
    Thanks,
    Wayne
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Welcome aboard wayne. Hopefully our resident Lehman expert "JIM" will be along shortly to help out if possible.
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Wayne...........Welcome to Trike-Talk.............
    2019 Tri-Glide.......
    Gone But Not Forgotten
    Tech Contributor
    Lee H. Mann's Avatar
    Apr 2011
    Martinsburg, WV
    Cool
    Quote Originally Posted by Wayski View Post
    Thanks,
    Wayne
    Wayne, welcome to Trike Talk from West Virginia.
    First thing, are you sure it is a Lehman Trike ??
    Sounds like something is broken or bent by your description.
    Pictures are helpful.
    Jim Murphy
    Iron Butt Rider 2001
    5+ Posts
    Apr 2019
    Cumming, GA, USA
    Quote Originally Posted by Lee H. Mann View Post
    Thank you for the warm welcome!!!!!
    I'm pretty sure, the previous owner kept all receipts for the conversion and then some, which also contained the warranty policy (photo enclosed)
    When I looked underneath the bike, I couldn't see anything which appears to be broken and/or nothing that appears to be broken or out of place.
    Rear Close.pdfRight Rear.pdfWarranty Policy.pdfRight side.pdfProposal Quote.pdf
  6. #6
    5+ Posts
    Apr 2019
    Cumming, GA, USA
    Default Thank you.....
    Thank you.......
  7. #7
    Dec 2014
    Grand Junction, Co. USA
    This might help:
    Name:  Rear Close.jpg
    Welcome to the Gang From Western Colorado.
  8. #8
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    Cool
    Wayne, It looks like the swingarm might be cracked after seeing the picture of the right rear wheel.
    Inspect, with a mirror and flashlight, the underside of the swingarm at the welded joints while weight is on the wheels.
    Inspect where the swingarm and rear axle housing connect as well.
    It is a straight axle unit (GTL) and even if it had only one shock on one side it shouldn't be listing like that.
    If you want more inspection info, contact me through www.mjtrikes.com
    Jim Murphy
  9. #9
    5+ Posts
    Apr 2019
    Cumming, GA, USA
    Jim,
    I tried to get a visual underneath the bike, but even with a mirror it was difficult to see anything. Later this evening I'll pop the tires off, get some jack stands under the axle and see if I can get a better look underneath to see if anything is more telling. However, I pulled the seat and I could get a clear visual of the shock and it is definitely compressed, i.e. the ripples on the black boot are compressed unlike the other side which is extended. When I lifted up the rear wheel well, I can the see the shock uncompress, but when I let go, it goes back to compressed with no hesitation.
    Wayne
  10. #10
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    Jim,
    Wayne
    Wayne,
    Just make sure that the swingarm has not cracked as a result of a failed shock.
    If you want to go back to the standard shocks (coil-over type) and not replace the air shock, you can get a 412 progressive for it.
    Depending on the seating weight for the future you can tailor make the shocks for your individual needs.
    The length is 13.25 - 13.5 around $300 for a set.
    The progressive air shock is $600.00 and needs to be special ordered.
    https://www.ebay.com/itm/Progressive...QAAOSw8bpcT4VV
    Jim Murphy
  11. #11
    5+ Posts
    Apr 2019
    Cumming, GA, USA
    Default Thank you
    Wayne,
    Jim,
    Thank you for this valuable information. I will let you know what I find out.
    In regards to the airshocks, as I'm not familiar with them, I'm assuming my air compressor needs to work in order to adjust them?
    Regards,
    Wayne
  12. #12
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    Cool
    Wayne, What did you discover ????
    Jim Murphy
  13. #13
    Apr 2010
    Shenandoah Valley of Virginia
    Wayne,
    The progressive air shock is $600.00 and needs to be special ordered.https://www.ebay.com/itm/Progressive...QAAOSw8bpcT4VV
    Ouch, now I know why CR gave me some "spares" ... and why I keep them.
    I had heard of rare swing arm cracks, but never yet seen one … yet I check mine every time I get near under her rear. I had wondered if the cracks I heard of were … pot hole induced or broken shock induced?
    A leaking air chamber of one shock would reduce PSI in both equally, so I see no advantage to OP's wanting to leave air shocks off. Id use them even if I had to plumb them to a tee and inflate with off-trike pump. Only way I see a Progressive 416 failing just one side and causing a cracked SA is broken internal suspension spring or shock mount. I worried about even especially that day up on Rt 50 in West Va about 10-12 years ago, brutal roadway.
    Anxious to see findings here!
  14. #14
    5+ Posts
    Apr 2019
    Cumming, GA, USA
    Default Update
    Lee,
    My apologies on just getting back to you. I just finished it up this morning.
    I ended up replacing both shocks, swing arm was fine, thank God
    What I found was even though I had air shocks on both sides, one was a Showa the other was Progressive.
    The Showa was completely shot and the oil was all over the right side swing arm. The Progressive was a little bit better, but as you can see, the rubber boot was separated from the upper shaft. It still had some pressure, so was a challenge to remove this one as my compressor is dead to release any of the pressure.
    I installed Progressive 412 shocks and as you can see from the photos, much better ground clearance than before
    I've only ridden it up and down the street and will hopefully, barring no conference calls, try to get it out on the highway. However, the ride just up and down the street was a much better ride.
    Thank you for your input and recommendations.
    Regards,
    Wayne
  15. #15
    5+ Posts
    Apr 2019
    Cumming, GA, USA
    Lee,
    Regards,
    Wayne
    Forgot to add the before and after pictures
  16. #16
    Apr 2010
    Wayski, I didn't open the four pdf (?) pics in your last two posts (my computer doesn't like them?), but if your solid axle Lehman GTL was leaning lower on one side, something is amiss with the swing arm as it's made very stout and rigid to not allow any lean, hence the "No Lean" name. NOT to argue, but if mine did that, I'ld either look for cracks in swing arm or at the bike frame at swing arm pivots until I found them. As Jim said earlier, a sound swing arm as it was built to be, would not allow leaning when parked. It was that rigid and more when built.
    But if you're happy, my wish is for nothing but safe rides for you.
  1. Freewheeler front tire/replacement recommendations
    By MDO in forum Harley Freewheeler / Road Glide 3
    Last Post: 08-25-2019, 11:15 AM
  2. Replies: 2
    Last Post: 07-04-2018, 05:57 PM
  3. Best rear shock replacement for Tri Glide?
    By Rooster57 in forum Harley Tri Glide
    Last Post: 10-17-2017, 09:34 AM
  4. Tr-Glide rear shock options with shock lift mount.
    By rick1201 in forum Harley Tri Glide
    Last Post: 02-12-2016, 01:50 AM
  5. Lehman Monarch II Auxiliary shock replacement
    By durango9 in forum Lehman Trike
    Last Post: 03-08-2015, 06:41 PM
