Likes Likes:  1
Results 1 to 8 of 8
Thread: Front Forks Stiff
    50+ Posts
    Apr 2019
    Fort Myers, FL
    Default Front Forks Stiff
    I just bought an ’03 GL1800 with a Champion kit. The front suspension feels like it is welded solid. Every little imperfection in the road comes right up the handlebars. When I stand on the pegs and “pounce” or “lunge” on the handlebars to try to bake the front-end bounce, there is not one bit of give to the forks. However, if the trike is slowly rolling forward and I slam the front brake, the front-end dives like expected.
    Being new to the trike world, is this normal? I’ve always heard that riding a Goldwing is like riding a couch, but not in this case. What weight oil should be in the front forks? I’m tempted to change it out for a lighter oil.
    Welcome to the Gang from Western Colorado.
    Guessing the stiffness is due to a rake kit. Look at the triple tree ... if it's black ... probably no rake kit ... aluminum ... rake kit. my 08 with the champion kit was the same way, not sure what to do about the stiffness.
    Mark..........Welcome to Trike-Talk.................
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    Hi Mark..Welcome to TrikeTalk from west Texas!
    May 2018
    Angleton, Texas
    To the Trike Talk Family! FROM SOUTH Angleton, TX
    Howdy Mark
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    Check with installer or previous owner. Sounds like progressive springs may have been installed in forks. Also check air pressure in front tire. 38 to 40 psi might help.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Quote Originally Posted by trikeman View Post
    This...
    Jun 2010
    Indianapolis, In.
    Do you know the following:
    1. Does the ADV work or is it stuck?
    2. Stock fork springs or something like progressives?
    3. How many miles since the forks were serviced, if at all? Might need a total rebuild using new OEM springs.
    4. What Pressure do you have in the front tire? I would not run more than 36psi
    Just because it has a rake kit(if it does)that will not make the suspension "rock hard"
    Puzzled by "front suspension feels like it is welded solid" but, then you say "if the trike is slowly rolling forward and I slam the front brake, the front-end dives like expected."
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
  1. leading link front forks
    By stevie in forum General Discussion
    Last Post: 01-29-2013, 09:34 PM
  2. Chrome Front Forks
    By VaThumper in forum Harley Trike Conversions
    Last Post: 12-05-2011, 04:44 PM
  3. Street glide trike custom front forks
    By edveitch in forum Harley Trike Conversions
    Last Post: 12-08-2010, 12:24 PM
  4. changing o rings in front forks
    Last Post: 02-22-2009, 02:49 PM
