Likes Likes:  4
Results 1 to 7 of 7
Thread: Suspension question
    80+ Posts
    Sep 2014
    SE New England
    Default Suspension question
    For the best ride possible question: I have a 2012 GL1800 with a Lehman Monarch II solid axle kit. I have installed the Lehman Heavy Duty (.400 dia. wire 270/345) Aux. shock. Front tire is at 41 psi and the rears are at 21 . My weight is 235 and my wife is 150.
    Question: what should the Aux. shock be set at? and what should the GL's mono OEM shock be set at?
    Thanks for your help
    Jun 2010
    Indianapolis, In.
    Some one else will have to help with the Lehman shock settings. As for the front tire pressure, lower it to 36psi, so you don't jar your teeth loose when you hit a bump! The Honda mono-shock should be set at the max of 25!
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by durango9 View Post
    Here is where I would set everything. There is no magic numbers, only easy starting places.
    Rear tire pressure 20 PSI hot, Front tire pressure 40-41 psi hot, (tire pressure can fluctuate as much as 2 psi on rear tires and 4 psi on the front between hot and cold) Aux shock #5 ramp (max spring pressure) and OEM shock #5-#7 single rider, #9-10 double up.
    These are default settings I use and you can tweak them (a pound at a time) as you ride.
    Jim Murphy
    Iron Butt Rider 2001
    Jun 2010
    Indianapolis, In.
    As for the front tire pressure. I too, fell pray to the age old suggestion of 41 to 42psi when I 1st triked. Even with the OEM front suspension it rode like a truck over bumps and dips and was absolutely terrible on railroad tracks! Finally wised up and lowered the pressure to 36psi and couldn't believe how much better the front suspenion felt!!! This was using a BT45, reverse mounted.
    BTW, if you have more than 25,000 miles on your 1800 Wing trike and especially if you have a rake kit, it's time for new OEM springs!!!
    Patriot Guard
    Was a LEO
    80+ Posts
    Sep 2014
    SE New England
    Default Suspension questions
    Thank you all for the inputs.
    I'm going to set the starting points as per Lee's suggestions and adjust from there. I'm game to try the front wheel psi at something lower than 41. In the past on 2 wheeler's I always set the front at 41 to prevent cupping on Dunlap's but now with an Avon Trike tire I'll try something softer.
    I do have 32K on the front tubes and a 5 degree rake. Good suggestion as to it may be the time to change the springs.
    80+ Posts
    Sep 2014
    SE New England
    Jim, as always you were right on with the below recommendations. My initial set was exactly what you said and I couldn't believe how good the ride felt. I did go back and adjust the OEM mono shock settings for fine tuning when 2-up vrs single and now the ride is better than ever. I did not touch the Aux from #5 and it seems to work fine for me.
    Thank you for your help and expert knowledge.
    Martinsburg, WV
    Thumbs up
    Jim Murphy
  1. Trike suspension question
    By vwbug72501 in forum VW Powered Trikes
    Last Post: 10-29-2015, 08:49 AM
  2. Oh No! Not Another Suspension Question!
    By Grandpa1 in forum Honda Trikes
    Last Post: 08-25-2014, 11:37 AM
  3. TriGlide Suspension Upgrade By Progressive Suspension
    By JohnC in forum Harley Tri Glide
    Last Post: 02-22-2012, 05:22 PM
  4. Which is best the Champion Independent Suspension or Solid Suspension.
    By glawrence7 in forum New Member Introductions
    Last Post: 11-24-2010, 12:00 AM
  5. Independent suspension vs straight axle
    By furofthedog in forum General Discussion
    Last Post: 04-16-2009, 02:34 PM
