LD-Ordie2Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie2LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  3
Results 1 to 10 of 10
Thread: Does the air suspension botton work when R/Smith trike added?
    Sep 2016
    Springfield, Mass. USA
    Default Does the air suspension botton work when R/Smith trike added?
    I have a 2010 Goldwing that was converted last season to a Roadsmith trike....
    It has been riding very rough lately, and I just thought about the air adjustment button on the faring.....DOES THIS WORK AFTER A CONVERSION?? like it did when this bike was a stock two wheel's vehicle??
    At what air number(s) do you like to keep for best riding smoothness, compared when pulling a trailer....????
  2. Roadsmith banner
  3. #2
    Jun 2010
    Indianapolis, In.
    I can tell you, it is not an air adjustment. That is a preload hydraulic pump.
    From the RoadSmith web sight:
    Adjustable Pre-Load
    The other suspension option we now offer is an Adjustable Pre-Load system. We tie right into the GL1800's existing suspension adjustment system that's controllable right from the dash. By the push up or down of a button, this system hydraulically pre-loads the fixed springs for various loads, and allows the rider to manually adjust the ride as they see fit. We use high quality Progressive coil over shocks combined with the springs.
    https://www.youtube.com/watch?v=fcvSvm5X9d0
    It appears to me, if you have the Adjustable Pre-load option, it uses the OEM Pre-load hydraulic pump.
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
  4. #3
    80+ Posts Wingrider55's Avatar
    Oct 2015
    Kingston, Illinois
    Adjustable Pre-Load
    If you have this system your pre-load pump may need to be rebuilt. I had to have mine rebuilt because the pre-load didn't start to do anything until it got to 11 on the pre-load.
  5. #4
    Jun 2010
    Indianapolis, In.
    Quote Originally Posted by Wingrider55 View Post
    What do you mean by rebuild??? All that is needed, as far as I know, is to make sure the pump is full. Seems Honda does not fill them full for some reason!
    Patriot Guard
    Was a LEO
  6. #5
    Sep 2012
    Lakeland, FL
    Very true what deputy dawg said. Don't believe the preload option was offered on my 2012 RS kit. If my recall is working, preload was disconnected with no option to connect. I know ABS was disabled.
    Oct 2015
    Kingston, Illinois
    Answer to your reply. My pre-load when new would start working at about 5. Over time it would not put any pre-load on until 11. I sent it to Traxion to have new seals and o-ring put in the pump and a steel braded hose put on. It now starts to put pre-load on at 1. The problem is not that Honda doesn't fill it all the way but that the plastic hose expands so you lose presser over time.
    Jun 2010
    Indianapolis, In.
    Thank you for your reply. There have been many posts on various forums of the pump not being completely full, which the case with mine.
    Patriot Guard
    Was a LEO
    Aug 2019
    Glasgow, Ky. 42141
    That is an option on Road Smith Trikes. You either have it or not.
    Barney
  10. Roadsmith banner
  11. #9
    300+ Posts
    Jun 2014
    S.E. Ohio,Close to the triple nickel
    Quote Originally Posted by Barney Biker View Post
    Barney
    This is correct. I built my own and added this option. I use it a lot. I pull a trailer 2 up and add preload or reduce preload as needed
  12. #10
    3250+ Posts Hot Rod 1's Avatar
    Jun 2012
    Saratoga County, New York
    My trike utilizes the preload system. My two settings are set at 13 & 15. The same settings I used when it was 2-wheeled.
  1. Motor Trike Air Suspension Air Bag Replacement
    By bassfisher in forum Honda Trikes
    Last Post: 04-23-2023, 11:23 AM
  2. Road Smith Suspension
    By bikerbillone in forum General Discussion
    Last Post: 07-16-2014, 06:45 PM
  3. ABS---Does it work?
    By Wingman08 in forum Honda Trikes
    Last Post: 03-21-2011, 06:48 PM
  4. Replies: 4
    Last Post: 12-09-2010, 10:52 PM
