Likes Likes:  2
Results 1 to 3 of 3
Thread: fork seal installer
    30+ Posts
    Mar 2019
    Henderson NV USA
    Default fork seal installer
    Is there a way to install the fork seals and bushings without buying the 43 mm fork seal installer tool? Anybody have a trick they use? Or do I just need to break down and buy the tool to make sure they're seated properly?
    Try a piece of Pvc pipe
    30+ Posts justlucky's Avatar
    Feb 2018
    northridgeville, OHIO, USA
    Default forks
    I used a pvc pipe and took a hack saw and cut it 3/4 through and used a rubber mallet , it worked for me.
  1. Front fork seal removal pain in the b***
    By RUMRUNR in forum Honda Trikes
    Last Post: 04-17-2017, 10:24 PM
  2. 2nd left fork seal in 60 days
    By cjmitch in forum Honda Trikes
    Last Post: 10-12-2013, 04:47 PM
  3. Leaking Left Fork Seal
    By Muleskinner in forum Honda Trikes
    Last Post: 08-11-2010, 11:18 PM
  4. Constant Fork Seal Leak
    By dive328 in forum General Discussion
    Last Post: 09-30-2008, 12:18 PM
