Results 1 to 6 of 6
Thread: I'm thinking about running a sidecar and a car tire on the back. Size? 2003 Dyna
    May 2019
    Killeen TX USA
    Default I'm thinking about running a sidecar and a car tire on the back. Size? 2003 Dyna
    I'm looking at sidecars and I hope to have one on my bike by spring at the latest.
    I want to run a car tire on the back after I get the sidecar but I don't know what size tire works with a 2003 Dyna.
    Doe's anyone run a car tire on a 99-05 Dyna?
    What size worked for you?
    400+ Posts Smitty901's Avatar
    Mar 2018
    Lowell, WI, US
    Quote Originally Posted by Jimmyess333 View Post
    Use this put in you bike tire size, then start comparing it to some car tire sizes soon you know if there is one close.
    Here is an example chose the over lay to compare. In the posted one it may be to wide keep looking you may find one that works
    https://www.tacomaworld.com/tirecalc...0r16-195-60r16
    May 2019
    Killeen TX USA
    That size may work with a chain drive conversion.
    I'm not sure if it would fit with the belt drive so I will have to do some measuring.
    Mar 2018
    Lowell, WI, US
    I posted that one as an example more research may turn up a better option. What is you stock size tire?
    Look at a 175/60R16 but avoid run flat or so called wheel protectors tire they will be slightly wider.
    May 2019
    Killeen TX USA
    yes 150-80-16 is the stock tire size.
    It looks like the size you suggested will work.
    thank you
    Mar 2018
    Lowell, WI, US
    thank you
    I have not searched out and tried every possible car tire yet. Packing heading out on a road trip. Nothing but riding planned for a while.
  1. Thinking about Sidecar?
    By madeinusa in forum Sidecar Forum
    Last Post: 02-10-2018, 04:39 PM
  2. tire size for rear tire on front? 2007 goldwing trike
  3. Dyna Bead,Tyre Balencer;Goldwing 175 x 15" Car front tyre
    By trikerAL in forum Tires, Wheels, Brakes, Front End
    Last Post: 10-24-2014, 09:27 PM
  4. Thinking about putting a side car tire on front wheel.
    By curley03 in forum Harley Trike Conversions
    Last Post: 09-30-2014, 01:40 PM
  5. 2003 dyna superglide with motor trike
    By Rlmolpus in forum Harley Trike Conversions
    Last Post: 10-18-2011, 09:18 PM
