Likes Likes:  1
Results 1 to 5 of 5
Thread: Handlebar vibration at 80 and above
    20+ Posts
    Oct 2017
    Spartanburg,SC,29307
    Default Handlebar vibration at 80 and above
    I own a used 16 triglide that only had 2000 miles, always had vibration in handlebars at 80 and over. New front tire that is well balanced, same problem. Could be neck needs adjusting, changed windshield with no difference, could be in damper. What else could it be? Thanks!
    Meme Master
    Jan 2014
    Farmington, NH USA
    80MPH and above...LOL, WOW!
    Sorry I couldn't help myself!
    No help with your issue either, sorry. Have you played with tire pressures? Could be simple as that?
    But bumping it back up in case someone has an idea for you.
    Good luck...
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by Vtrod View Post
    Check the rear wheels for balance. They can cause a terrible shake if even one is out of balance. And, as suggested above, lower the rear tire pressure to 20-22 psi and make sure your rear suspension pressure is below 30 psi too.
    Jim Murphy
    Iron Butt Rider 2001
    10+ Posts dabimf's Avatar
    Mar 2018
    Havelock, North Carolina USA
    Check to see if the steering dampener/stabalizer is ok.
    30+ Posts Lance65's Avatar
    Dec 2016
    cleveland ohio 44119
    Default Bad vibrations
    Several yrs. ago I bought a part on line called a 'Vibranator' that you placed inside your handlebar ends (not the ones that stick out the ends). Since then I have had no handlebar vibrations . i don't know if they still make them ..
    Lance
  1. Stallion won't rev above 3000rpm
    By minterdad in forum Stallion Trikes
    Last Post: 04-03-2013, 07:48 AM
  2. Motor Trike went above and beyond !!!
    By sandrooney in forum Motor Trike
    Last Post: 07-29-2012, 12:03 PM
  3. The Person Above You
    By Papa Zook in forum General Discussion
    Last Post: 09-16-2010, 06:36 PM
