Results 1 to 4 of 4
Thread: gear ratio
    40+ Posts
    Mar 2019
    Myrtle Beach
    Default gear ratio
    has anyone ever changed the gear ratio i belive mine is a 4.10 like and put 3.55 in it
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    Do a Stallion search. Think someone posted on TT about changing to higher gears to get better MPG. Adverse effect. No increase in MPG and more back and forth shifting in hill country riding. Changed back to stock.
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    Quote Originally Posted by trikeman View Post
    I have, in the past, spoken with TMS about this and they said the same thing! Stick with what's in it! If you want better mileage, use non ethanol gas. When I was in Arkansas for a couple of TrikeTalk gatherings, my mileage went to over 40 mpg as there are/were numerous gas stations with regular non ethanol gas. I always got better mileage when I got out of Florida because off the additives they use here. Tomg
    450+ Posts rocket1lf's Avatar
    Dec 2013
    Hot Arizona, USA
    That was me. I dropped to a 3.73 and went back to the 4.10. Not enough torque in the little 4 banger to keep it from downshifting for every little hill. Rick
    Stallion #378
    Suzuki Burgman 650
  1. Replies: 8
    Last Post: 07-06-2016, 09:27 PM
  2. Best final gear ratio for V Star 1100 trike ?
    By Pre-1898 in forum Yamaha Trikes
    Last Post: 08-21-2013, 07:31 AM
  3. motor trike rearend question gear ratio
    By MACHINIST15 in forum Honda Trikes
    Last Post: 07-22-2013, 10:52 PM
  4. Need help with gear ratio
    By REOFL in forum Honda Trikes
    Last Post: 10-05-2010, 09:42 PM
  5. What is the ratio
    By Goldwingtrike in forum General Discussion
    Last Post: 04-07-2009, 09:41 AM
