SSpoon5trike ladyNew Member Introduct...Hello from VA
gfaltersack1gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon5SullyNew Member Introduct...Hello from VA
SSpoon5Jack KlarichNew Member Introduct...Hello from VA
SSpoon5GorillaNew Member Introduct...Hello from VA
SSpoon5SSpoonNew Member Introduct...Hello from VA
Likes Likes:  10
Thanks Thanks:  8
Page 2 of 2 FirstFirst 1 2
Results 21 to 31 of 31
Thread: Brake warning light
  1. #21
    Contributing Member Captain H's Avatar
    Nov 2010
    Salisbury, Ma. USA Jan. & Feb.in Silver Springs Fl.
    Quote Originally Posted by ST1300 View Post
    After much research and phone calls I have purchased a Valve from Master Power Brakes. It is model VL 3359, Universal Combo Valve. They were great to work with. I will report back when I get it installed.
    Jeff
    Hi Jeff, did everything go good , and the warning light go out ?? I have the same thing happening with my 2009 .
    thank you , captain h
  2. #22
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    Keep in mind in order to get the valve recentered you have to bleed fluid out of the opposite system. In other words if it was a car and you did work to the front brakes you would open the rears to bleed. Sometimes takes a minute for the fluid to bleed down. Someone watching the light can be helpful. It can go to far then the process starts over again.
  3. #23
    20+ Posts ST1300's Avatar
    Oct 2018
    Naches , Wa USA
    Sorry for not getting back sooner. I replaced the bias valve and after several times bleeding the brakes I have great brakes. The buzzer is still chiming at me so that must be another issue
    Jeff
    :AllGood:
  4. #24
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    [QUOTE=ST1300;687327]Sorry for not getting back sooner. I replaced the bias valve and after several times bleeding the brakes I have great brakes. The buzzer is still chiming at me so that must be another issue
    Jeff can you advise what you used for a replacement bias valve? Was it Ford or ? Part number? Direct replacement or adaption required?
    Thanks,
    Ted
  5. #25
    Oct 2018
    Naches , Wa USA
    [QUOTE=Gorilla;687345]
    Thanks,
    Ted
    The valve came from Master Power Brakes and the part # is VL 3359. If you go to there web site you will see just the valve or a kit containing the valve and everything needed to change it. If yiu get just the valve be sure to get the tool for bleeding it also.
    Hope this helps
    Jeff
    :AllGood:
  6. #26
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    [QUOTE=ST1300;687536]
    Quote Originally Posted by Gorilla View Post
    Hope this helps
    Jeff
    Thank you for posting the information ride safe
  7. #27
    250+ Posts
    Dec 2010
    oly,wa
    Hi Jeff
    don't mean to hijack your thread Jeff, but can anyone post a wiring diagram for the brake system. this might help, if it doesn't help you it will really help me
    Dragon
  8. #28
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Quote Originally Posted by Dragon View Post
    Hi Jeff
    Dragon
    Chuck are you looking for the brake switch wiring or what exactly?
  9. #29
    250+ Posts
    Dec 2010
    oly,wa
    good morning
    the brake switch mostly yes, but all would be nice
    Dragon
  10. #30
    300+ Posts
    Apr 2011
    Signal Mountain Tn
    Jeff
    Here is the link for the valve. There are three options to purchase the valve. Looks like one would need to purchase the kit with parts they don't need to get the bleed tool, which is $20. more than just the basic valve.
    https://www.mpbrakes.com/pc_combined...word=VL%203359
  11. #31
    250+ Posts
    Dec 2010
    oly,wa
    Good morning
    according to the wiring diagram, only 2 places activate the brake light warning, brake fluid level in reserivor and emergency brake switch, another thing to look for is you might have a burned out light in the instrument panel. seeings how some of the wiring harness have been left off door ajar ect, there might be a light burned out causing a short. just a thought
    Dragon
  1. Trunk Lid Warning Light
    By joeychitwood in forum Harley Tri Glide
    Last Post: 01-21-2018, 11:08 AM
  2. Unidentified Warning Light and Chime
    By FaithRider in forum Stallion Trikes
    Last Post: 01-31-2016, 05:48 PM
  3. Replies: 3
    Last Post: 03-01-2015, 12:16 AM
  4. auxillary brake light.,turn signal running light conversion
    By fogrider in forum Harley Trike Conversions
    Last Post: 08-25-2013, 09:24 AM
  5. Head Light Warning Buzzer
    By Mattel in forum Stallion Trikes
    Last Post: 08-10-2011, 03:30 PM
