Likes Likes:  10
Thanks Thanks:  8
Results 1 to 20 of 31
Thread: Brake warning light
    20+ Posts ST1300's Avatar
    Oct 2018
    Naches , Wa USA
    Unhappy Brake warning light
    I have the brake warning light lit on my 2008.
    Just bled the brakes front and rear. Any suggestions on where to start checking?
    Thanks.
    Jeff
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    Check fluid level.
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    Quote Originally Posted by ST1300 View Post
    Thanks.
    Jeff
    Call Richard at TMS and ask him, there could be a reset process. Tomg
    What I believe you have is the switch on the bottom of the proportion valve back by the master cylinder is being activated. That valve is there for if either the front or the rear system failed the valve will cut off fluid to failed system leaving the other system functioning put at a much reduced rate. When you bled the brakes you might have allowed that piston in there to move enough to activate the switch but probably not enough to block one of the systems. I found that a hard application of the brakes a couple of times helped to center the piston.
    Oct 2018
    Naches , Wa USA
    Thanks! I will check it out and report back.
    Oct 2018
    Naches , Wa USA
    Thanks. I will try that.
    Oct 2018
    Naches , Wa USA
    Quote Originally Posted by trikeman View Post
    Check fluid level.
    I did. All good.
    Oct 2018
    Naches , Wa USA
    So far I have checked the brake fluid level and its right where its supposed to be.
    I went out for a ride and applied the brakes very hard several times. It will stop fast with no dart or weave. It will lock up the front brake on a panic stop. Warning light is still on. Any more suggestions?
    Jeff
    Oct 2010
    Try disconnecting ground cable for a few minutes
    Oct 2018
    Naches , Wa USA
    So far I have checked the fluid level and its good. I have did hard stops from several speeds. I have unhooked the battery and grounded the cables together. I have unhooked the wire to the emergency brake and checked it. No luck so far. Light and warning buzzer still on!!
    Any other tips will be appreciated.
    Jeff
    :AllGood:
    Question, why did you bleed your brakes?
    Was this light on prior?
    Did you run the master cylinder low when bleeding?
    Was your brake pedal low and spongy prior to bleeding?
    Most metering/ combination valves are NOT serviceable in the field
    This means once the pressure difference is detected you will set a light and it will not go out until the failed unit has been replaced and brake system is bleed properly
    Oct 2018
    Naches , Wa USA
    Was this light on prior? No
    Did you run the master cylinder low when bleeding? No
    Was your brake pedal low and spongy prior to bleeding? Yes
    Is it time for me to think about replacing the proportioning valve?
    :AllGood:
    That all depends,
    I have seen this problem many times with no ill affects to the braking system, however should a failure of 1 axles brakes happen you would not know until you applied the brakes
    IMO it all comes down to trust and safety
    I have 1 more question for you, does your master cylinder have a float inside or an electrical wire running to it?
    If it has a float it could be stuck causing the light to stay on
    I am not familiar with your set up, if I saw a picture of it I could give a better answer
    In the end we have to trust our brakes no matter what we ride
    Your answer to question about brakes being low or spongy was yes?
    While you have bled your brakes it is worth doing it 1 more time
    It does not take much pressure difference to set a brake light
    Have a helper pump the brakes with even slow pumps then crack the bleeders open 1 at a time
    See if that resets your light
    If not the valve is going to have to be replaced
    Oct 2018
    Naches , Wa USA
    I will rebleed them and see if that works. Thanks for the help.
    And yes they were soft and spongy before I bled them. The back brakes were full of air and I had almost no rear brakes.
    Jeff
    :AllGood:
    Oct 2018
    Naches , Wa USA
    It's been a while but I have rebled all of the brakes , checked everything I know to check and still the brake light is still on , on the dash. Looks like I need to replace the brake balance valve. Can anyone tell me the part number I need to look for?
    Jeff
    :AllGood:
    Before you look at replacing the valve,
    Does this valve had a wire running to it? If it does unplug it. Is the light still on?
    Most brake systems use this and a combination switch @ the parking brake. If the parking brake does have a switch it too can cause the light on if the pedal is not returning far enough to trigger the switch. By unplugging the wire @ the combo valve by the master cylinder you can confirm if the hydraulic system is the culprit. Good Luck
    Oct 2018
    Naches , Wa USA
    I have checked the circuit by removing the wire at the brake lever end and that is not the problem. I then unhooked the wire at the valve and the light and buzzer stopped. The culprit is in the valve so I need a part # for a new one.
    Jeff
    :AllGood:
  19. #19
    Jeff
    sorry i don't think anyone has replaced that part.
  20. #20
    Oct 2018
    Naches , Wa USA
    After much research and phone calls I have purchased a Valve from Master Power Brakes. It is model VL 3359, Universal Combo Valve. They were great to work with. I will report back when I get it installed.
    Jeff
    :AllGood:
  1. Trunk Lid Warning Light
    By joeychitwood in forum Harley Tri Glide
    Last Post: 01-21-2018, 11:08 AM
  2. Unidentified Warning Light and Chime
    By FaithRider in forum Stallion Trikes
    Last Post: 01-31-2016, 05:48 PM
  3. Replies: 3
    Last Post: 03-01-2015, 12:16 AM
  4. auxillary brake light.,turn signal running light conversion
    By fogrider in forum Harley Trike Conversions
    Last Post: 08-25-2013, 09:24 AM
  5. Head Light Warning Buzzer
    By Mattel in forum Stallion Trikes
    Last Post: 08-10-2011, 03:30 PM
