BigN693GorillaEnabled TrikersFull length floorboards
Likes Likes:  8
Thanks Thanks:  3
Results 1 to 16 of 16
Thread: 2019 Trike Lifting Blocks
    100+ Posts Koolbreeze's Avatar
    Oct 2018
    Stewartstown, PA, USA
    Default 2019 Trike Lifting Blocks
    It is raining here so I decided to make some lifting blocks to help when jacking up the axle as it is always a pain to get a jack in there to lift. I find using a scissors jack on the frame like is shown in the manual to lift the rear basically lifts the entire trike even when the front wheel is brake locked and tied down.
    I made some blocks as shown below to fit over the tie down loops on the rear axle pinch block. The part of the pinch block with the loop looks to be welded to the axle and should provide a good support point for jacking. I have 2 floor jacks and will probably use both to lift the rear and then set the axle on jack stands. Used a couple of 6-inch 4x4 pieces and drilled out a slot 2 inches long 3/8 inches wide and 1 ¾ inches deep. Used a wood chisel to clean it out. They seem to work just fine.
    Any input for any issue with using them to jack the trike would be appreciated. I do not think using these will damage anything. Thanks for looking.
    Tie down loops on axle pinch block:
    Home made blocks:
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    That will work fine
    Good job
    1000+ Posts
    Aug 2016
    Des Moines IA US
    Looks good to me, I made one out of a 2 x 4 but have never used it yet so I really don't know if it will work, had the 2 x 4 laying around, cut off a chunk and drilled the holes for it to fit the loop, have heard of the loop bending when using a floor jack so I thought of this, you went with a 4 x 4 which would work better and stronger, I haven't used mine yet so don't know if it will work, one of these days, LOL
    All for now Trampas
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Great idea. Thanks for posting with the pics. Went right out and made a set. Super easy and quick. Heck it took me longer to move stuff to get to my saved stack of leftover lumber and find the 4 x 4 I knew I had than it did to actually make them. This will work great.
    1500+ Posts ShapeShifter's Avatar
    Aug 2018
    SW, Arkansas, USA
    Thumbs up NICE!
    Great Idea.
    2016 Tri Glide Billet Silver w/Pinstripes ["Hi-Yo, Silver! Away!"]
    • "There is so much good in the worst of us, and so much bad in the best of us, that it ill behooves any of us to find fault with the rest of us." ..... James Truslow Adams
    • 2nd BN 33rd Armor "The Tiger Battalion" "1972 - 1974"
  6. #6
    Sep 2016
    Springfield, Mass. USA
    Excellent idea! I did the same last season, for my three wheels, it sure makes it much easier to get under motor to change out oil and filter..
    Ronnie
  7. #7
    40+ Posts
    May 2016
    West Coast BC Canada
    Default Trike Lifting Blocks
    I made the lifting blocks but found the base of my small jacks interfered with where I wanted to put my jack stands, so I ended up just putting blocks under the rear wheels. Did you do anything different? I think I might make ramps this off-season.
    Ron
  8. #8
    5+ Posts
    Nov 2019
    Port Saint Lucie
    I like what you did. Did you center the opening or did you or off to side? Thanks
  9. #9
    Oct 2018
    Quote Originally Posted by Limited View Post
    Side to Side they are centered. Front to rear they are a little forward to account for the length of the pinch block so they support it the entire length, hence the arrows and right left marking. I held the bock's up to the loop and tapped the bottom of them with a hammer to get a make on where the cutout would be.
  10. #10
    Dec 2013
    Clarion PA USA
    Quote Originally Posted by ultrafxr View Post
    Yep! 4X4 are always on the bottom... just sayin... I may make a pair of those also. Good thinking Travel safe Fred
  11. #11
    1000+ Posts
    Aug 2016
    Des Moines IA US
    I know this thread is old but I thought I would say my 2x4 worked good for me, I posted above saying I did this way before he posted this about using a 4x4 but have never used it to say it worked, now I am. I used my 2x4 to jack up the trike so I could put on my lift kit, I only made one 2x4 so I jack up one side and put jack stand under frame and then the other, work good for me.
    Just thought I would update this since my 2x4 worked for me, granted a 4x4 would be even better, didn't have any at the time, may do this again since now I have some scrap 4x4's since a storm took out 30 feet of my wooden fence.
    All for now Trampas
  12. #12
    300+ Posts
    Dec 2014
    florissant
    I made mine out of 2x4's back in2016 and have been using them ever since. There are several ways to jack the trike up and depending on what i'm doing this is just one way to do it. Floor jack on the rear most brace under the trunk and then place jackstands on the forward brace is another way of supporting the trike.
    hardheaded
  13. #13
    500+ Posts tis's Avatar
    Dec 2008
    West Falls, N.Y.
    Default Lift Blocks
    I used a 2X6, & it worked great...Tis
  14. #14
    Contributing Member ROAD DOG's Avatar
    Jan 2009
    MA,
    Quote Originally Posted by tis View Post
    HAY TIS Were hell you been ????????????????????????
  15. #15
    Dec 2008
    West Falls, N.Y.
    Been real busy & time just flew by, Wife still hasn't been able to ride with me yet & thats been going on 4 years, she still useing Walker & now starting to use cane a little bit. It's been a long journey, I've often thought of you guys & when I was going to send you a msg. something always came up. One of the worst things I hate about this situation is I still have to do all the shopping & I just hate it.. hope your all staying healthy & safe, do you still have the Honda? Say Hi to your Wife & I'll try to stay in touch..
  16. #16
    Jan 2009
    MA,
    Good to hear from you, Happy to hear your ok, hope the wife gets better soon. No like a dumb ass I traded it for another shit bag Harley ! I was telling the wife today that We got to take a ride and see Tis this summer . Really Great to hear from you young Man
  1. How about this jack for lifting a trike?
    By scribe5 in forum Honda Trikes
    Last Post: 04-17-2019, 03:47 PM
  2. Lifting up a trike
    By Reddun in forum Honda Trikes
    Last Post: 08-28-2012, 05:10 PM
  3. Lifting RSV Hannigan Trike
    By leo3wheel in forum Yamaha Trikes
    Last Post: 04-05-2012, 07:25 PM
  4. Lifting Front of Goldwing Trike
    By Muleskinner in forum Honda Trikes
    Last Post: 09-20-2010, 09:13 AM
  5. Lifting a Trike
    By rmrc51 in forum General Discussion
    Last Post: 04-29-2010, 01:26 AM
