Results 1 to 9 of 9
Thread: Rubbing noise
    700+ Posts jjvw's Avatar
    Dec 2013
    Jenison, MI
    Default Rubbing noise
    I have a champion kit on my roadstar. We have 50k on the kit. On a ride yesterday, we noticed a rubbing sound as we did a left side u turn. I haven't tried a right side u turn yet. I check tire clearance and lug nuts. It sounds like rear drive train noise to me. Belt tension is ok. I had the body off, last summer for a check up and everything was tight and in spec. Any ideas besides not doing u turns?
    Jan & John
    I hate stuff like this ... could ne lots of stuff. I'd put the trike rear wheels off the ground and check for wheel bearing play, get the trike in neutral and spin the power train from the wheels.
    I'm guessing it doesn't do it when going straight? When it's up "wiggle" and "turn" everything you can and look for play and listen for noise.
    Dec 2013
    Jenison, MI
    Thanks. I will do that, when I get thru rebuilding the TBI in our motorhome. Gramma wants to camp on the beach next week.
    Quote Originally Posted by jjvw View Post
    If Gramma ain't happy, nobody's happy ...
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    Ditto on keeping Gramma happy.Check the swingarm for looseness.
    1989 GL1500 Goldwing (SOLD)
    2006 GL1800 CSC
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    John, check your shocks. Might be a tire rubbing when under a load. Where is your shock preload set at? You can rotate it a notch or three on both sides to increase preload and that may cure the issue, or if they are the original shocks, it's probably time to replace them.
    Feb 2020
    Wellington,New Zealand
    Jan & John
    I have the same issue what was the fix for you
    thanks
    20+ Posts
    Feb 2022
    tucson az usa
    Jan & John
    Is that Independent Suspension?
    20+ Posts
    Feb 2022
    tucson az usa
    Default oops
    Didn't notice this is an Old Post""""
    But I do have New Shocks I would like to sell....For Ind. Suspension.
  1. Loud rubbing noise when turning or going slow
    By Motogordo in forum Lehman Trike
    Last Post: 05-30-2019, 06:16 AM
  2. Victory Trike Owners- Are you having issues with seat rubbing Tank?
    By SEE THROUGH BRAZ in forum Victory Trikes
    Last Post: 05-15-2016, 01:50 PM
  3. Belt drive rubbing battery box MT
    By mcdonaldroadcapt in forum Motor Trike
    Last Post: 06-18-2013, 06:35 AM
