Likes Likes:  28
Thanks Thanks:  13
Page 2 of 2 FirstFirst 1 2
Results 21 to 36 of 36
Thread: charging issue???
  1. #21
    Quote Originally Posted by Fowler View Post
    You know what I just painted my alternator stand.
    Could it be that I am not getting a good ground there?
    I will try the ground strap idea before I replace the alternator
    The alternator should ground to the engine and the engine should ground to the frame
    You can check for grounds with an ohm meter
    A bad ground can cause erratic volt readings and cause over heat issues also
    Adding extra grounds will not hurt in fact you may find them to help
    Clean and tight grounds
  2. #22
    If the paint is thick enough, You probably aren't getting a good ground, Just file it down to bear metal at the alternators bolt down spots...
  3. #23
    Apr 2015
    Batesville, AR. 72501
    Since the VW alternator clamps in a saddle in the stand with a band. I'd say pull the alt and clean the paint off the inside of the stand saddle area where the strap surrounds the alt and the alt saddle area and reassemble. Maybe a small piece of aluminum screen wire in that area between the alt and stand will help with a gas-tight electrical connection from alt to engine and won't mess up your new paint job.
  4. #24
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    replaced the alternator
    Still the same
    At 700 - 800 RPMs the voltage is 12v- 13v
    above 800 RPMs it jumps up to 14.5
    here is my diagram
    http://3fowlers.com/images/photos/manual/trike_3.jpg
    Thank you
    Bob
  5. #25
    Still the same
    Both my Tri-Glide's at any rpm's over an idle the gauge showed 14+. With out any ill effects..........
  6. #26
    What does your battery read with out engine running?
    Anything above battery voltage @ an idle should be fine
    Fully charged battery reading 12.7 volts
    So if your volt meter is showing say 12.9 to 13.5 @ idle should be OK( keep in mind this is no super Alternator nor does it have to be)
    14.5 @ higher RPM is fine
    You should check the volt reading from the battery wire on the alternator to compare it @ the battery The reading should be with in 1/2 volt
    7-800 RPM is kind of low IMO maybe bump it up to 900 see what your voltage is
  7. #27
    Sep 2014
    Moneta VA
    OK here are my readings
    before starting
    Battery - 12.67v
    Alternator - 12.67v
    Running
    800 rpms - 12.38v
    900 rpms - 12.49v
    1000 rpms - 12.70v
    1400 rpms - 14.38v
    Running, battery wire removed from alternator and voltage tested at alternator
    900 rpms 15.24v
    I wish I would have ran this test before replacing the alternator
    reconnected wire to alternator
    set to 900 rpms
    ran for 20 minutes at idle to simulate stuck on the road due to the recent road work around here
    The voltage never went below 12.45
    shut down the engine
    12.67V
    Summery
    the voltage reading fluctuated up and down just a little on each reading but the above is about where they were
    The battery is being kept charged
    I think it will be OK so I'm going to leave it as it is.
    Next project on this trike
    Next I want to adjust me carburetor. I have not adjusted it for years and it seems to be running a little rich
    http://3fowlers.com/carbsetup.html
    Thank you
    Bob
  8. #28
    50+ Posts chopptrk's Avatar
    Mar 2016
    louisiana,usa
    "ran for 20 minutes at idle to simulate stuck on the road due to the recent road work around here"
    Funny, but the true.
    Seems those numbers are good, makes me glad that I don't have any gauges, .
    Good luck on the carb, they can be tricky. My last one drove me crazy (cheap & old).
  9. #29
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    The only thing I can add, is to check the wiring #10 circuit from ign sw, to terminal board, to the alternator lite connections, then to the alternator This may be supplying the excitation voltage to start the alternator charging....worth a look!
  10. #30
    Sep 2014
    Moneta VA
    Quote Originally Posted by LarryA View Post
    yep checked that
    don't remember the exact voltage but it was above 12v
    Thank you
    Bob
  11. #31
    Running
    800 rpms - 12.38v
    900 rpms - 12.49v
    1000 rpms - 12.70v
    1400 rpms - 14.38v
    Are these tests made with lights or anything else on?
    I would still expect to see your original 12.7 volts even @ lower RPM
    You are using more battery voltage @ lower RPM than you are making
  12. #32
    Sep 2014
    Moneta VA
    Running
    800 rpms - 12.38v
    900 rpms - 12.49v
    1000 rpms - 12.70v
    1400 rpms - 14.38v
    All lights on and headlight on high beam
    all the eye lights on to (lights in the skull eyes)
    Amp powered up
    GPS on
    I guess I should have turned all that off
    Thank you
    Bob
  13. #33
    Amp powered up
    GPS on
    Now it makes more sense to me
    Test it with just head lights on to see what you have
    I think you should be OK now
  14. #34
    Sep 2014
    Moneta VA
    Default the problem came back or actualy never left
    I thought it was fixed but was wrong
    Should have listen to you Jack
    the voltage started dropping down to 10v again
    this time I disconnected every circuit not needed to actually run
    it started charging fine
    I then reconnected each circuit 1 at a time
    It turned oy to be the Headlight circuit
    Thought it was the dimmer switch but that turned out to be OK
    disconnected 1 headlight still had the issue
    disconnected the other headlight and the issue went away
    put the headlight back the issue came back
    replaced the headlight and the issue is gone
    Now at idle and with everything on it charges above 13v
    the bad headlight was still working just drawing to much
    Thank you
    Bob
  15. #35
    Good deal Bob
    Sometimes Lectricity can be a real pain
    Now that you have it charging @ 13 volts you should be OK
    Thanks for checking back in and good luck
    PS, if you still have your old alternator now would be a good time to have it rebuilt and up the amperage
  16. #36
    450+ Posts
    Mar 2018
    Fernley
    Wow, who would of thought about that, Jack did !
    Always learning something new here about something. Thank you everyone for your input and help, this can help many of members...................
  1. Battery charging prob.
    By lboos in forum Harley Tri Glide
    Last Post: 12-17-2014, 06:00 PM
  2. up date on battery charging prob.
    Last Post: 11-08-2014, 06:45 PM
  3. Batt. charging prob. update
    Last Post: 10-27-2014, 12:59 PM
  4. Roadhawk Charging Problem ?
    By 2blackbelts in forum VW Powered Trikes
    Last Post: 05-09-2012, 11:14 PM
  5. my t/g battery charging fix
    By eagle1 in forum Harley Tri Glide
    Last Post: 03-07-2012, 11:52 AM
