Likes Likes:  9
Results 1 to 15 of 15
Thread: Help, windshield cloudy gl1800 windshield
    50+ Posts
    Jul 2009
    Paris, tx USA
    Default Help, windshield cloudy gl1800 windshield
    How do I get the “cloudy film” off a gl1800 windshield? I have tried 1500 grit sandpaper but think I may have scratched the windshield some. I can scratch it off with my fingernail. I was told to use a soft cloth and polish but it did not come off.
    Quote Originally Posted by jnorth View Post
    I have a rhino with a full windshield and i ride though heavy brush and branch's constantly and I polish it with a scratch remover polish ‘ and it works wonders on my ten year old windshield 👍👍 I’m not home right now but will be in an hour and post the name of the polish 👌
    Ok. I'm back......The name of the polish is..Novus Plastic Polish No 2.....
    I put it on my windshield and rub it in with my fingers....No cloth, Just fingers till it's dry, Then with a clean cloth wipe clean.........
    50+ Posts
    Jul 2009
    Paris, tx USA
    Thank you, I will try Novus plastic polish no2!!
    Should work, I know my Rhino's windshield takes a beating .....And the Novus works....
    I just hope you didn't go caveman with the sandpaper on yours......
    Let us know if it works for you.......
    50+ Posts
    Jul 2009
    Paris, tx USA
    Thank you, I will let you know, I had to order it and it should be here in a week or so
    My bad.......I should have told you to park the Honda off site at a Harley dealer and go in wearing a Harley T shirt.....Most Harley dealers in my neck of the woods carry the Novus.....
    Every HD shop I have been in carries it
    I found it cheaper @ Auto Zone
    50+ Posts
    Jul 2009
    Paris, tx USA
    Default It is on the inside of the windshield
    Quote Originally Posted by HOLLIDAY View Post
    Sounds like you have a scratch guard coating if you can pick it off with your fingernail. Keep going with the 1500 wet till all of coating is gone. Then go to 2000 micro fine wet, switch from horizontal strokes to vertical strokes, slight buffing with muslin wheel and just about any polish will bring it back to perfect clear.
    The film is on the inside of the windshield, but it has put a lot of scratches while sanding it. Have been out of town and will start trying to fix it again. Our Honda house (where I bought my gold wing new) has converted to a Harley house lol , don’t see many Honda’s in the parking lot!
    Sep 2016
    Springfield, Mass. USA
    I don't know if this will actually help or not, BUT I always give my windshield a good wax job everytime time I wax her up.........which is usually everytime it rains for the day, I'll sit in my garage, and put my "headphones on, listen to my favorite band "led zeppelin" and "rock out" and wax her up!!
    50+ Posts
    Jul 2009
    Paris, tx USA
    Default Got most of film off
    Got most of film off but now am dealing with a lot of scratches on windshield, so many I can’t see through it. I have a buffer and will see how buffing it with novus works.
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    I know you guys like to work at a project to see if you can successfully achieve your end goal.... BUT... just as a suggestion.... if all else fails and it comes down to NEED A WINDSHIELD NOW you might want to purchase an F4.
    Very pricey - yes. Probably be the last one you’ll ever need. Water and paper towels is usually all you need to clean it up. Yes... paper towels! They will NOT scratch it. You can use Windex if you think you need it. - NEVER put wax on it. Optical clarity is fantastic. It is a a much heavier material than the OEM shield.
    And, by the way... get that windshield issue done and come on down to Kerrville for the TrikeTalk meet and greet at the end of September...its a fun time with lots of riding and kick’n tires!
    1500+ Posts
    Oct 2012
    Batavia Ohio
    My suggestion is to pitch it and buy an F4. Like the man said, it will be the last one you'll ever need
    50+ Posts
    Jul 2009
    Paris, tx USA
    Default Thanks al
    Quote Originally Posted by paws View Post
    Thanks all for the input. It did work by sandpapering it and then polishing it. I can ride and see through it . It will work for a while until I decide to bite the bullet and buy a new windshield lol. I will look at a f4 but just can’t afford one right now!!
    Aug 2019
    Glasgow, Ky. 42141
    The GL1800 shields are coated and if peeling off you just as well throw it away.
    Get a better replacement.
    Barney
  16. Roadsmith banner
  1. Help Needed From 2004 Lehman GL1800 Owners
    By Ray & Paula in forum Lehman Trike
    Last Post: 06-05-2023, 05:35 AM
  2. Whos Faster ? GL1800 or GL1800 Trikes ?
    By Motogordo in forum Honda Trikes
    Last Post: 09-26-2017, 10:16 AM
  3. Opinion---Best windshield for GL1800 Trike
    By tndragonrider in forum Honda Trikes
    Last Post: 03-31-2016, 03:52 PM
  4. 08 Gl1800 Engine rattle maybe HELP
    By Bare in forum Honda Trikes
    Last Post: 07-05-2014, 04:21 PM
