Results 1 to 2 of 2
Thread: Motor Trike Conversion
    90+ Posts pddgm's Avatar
    May 2014
    Sunrise Beach, MO
    Default Motor Trike Conversion
    I have a 2008 Electra Glide with a Motortrike conversion kit, all of a sudden it has gotten hard to turn left if going into a sharp turn or down a hill into a curve. Checked the front tire and it's looks good, no signs of wear or cupping. have the airbags set at 15 lbs and there is little or no sway in the body. Does not do it turning right, no matter how hard the turn, doesn't do it at low speed, just seems to do it at 25 mph or above.. Can't figure out if it's the trike or me. Any ideas???? Totally baffled...
    check the steering stem nut it might be loose. also maybe the bearing in the stem need replacing worth checking
  1. recently bought 07 harley trike with motor trike conversion
    By Ralph C 123 in forum Harley Trike Conversions
    Last Post: 06-09-2018, 02:57 PM
  2. Goldwing Conversion Motor Trike Adventure
    By feaver in forum Motor Trike
    Last Post: 08-27-2012, 12:58 PM
  3. Rattle 05 RK Motor Trike conversion.
    By sandrooney in forum Motor Trike
    Last Post: 06-12-2012, 06:16 AM
  4. 2008 Classic Ultra Motor Trike Conversion
    By XTCM8 in forum Harley Trike Conversions
    Last Post: 06-07-2011, 05:03 AM
  5. Orderd my Motor Trike conversion today!
    By ThreeAces7 in forum General Discussion
    Last Post: 08-06-2010, 10:48 PM
