ctdair7Jack KlarichHarley Tri GlideHot Rotors After New Pads
Phu Cat2trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat2Phu CatGeneral DiscussionIs there a TV commercial
Speed Bleeders
Likes Likes:  3
Results 1 to 16 of 16
Thread: Springer Front End
    10+ Posts Lost Newfie's Avatar
    Sep 2018
    Arnprior, Ontario, Canada
    Default Springer Front End
    Getting ready to assemble my springer after painting. Looking for the proper torques and procedure to rebuild. Should I use red locktite along with Torquing? Any help would be appreciated.
    If you can't find application specific values, try searching with google or bing for generic torque values like this chart:
    https://www.portlandbolt.com/technic...-torque-chart/
    Sep 2018
    Default Rockers
    I have a good torque chart for the regular bolts. I am more worried about how tight to set the rocker bolts. So that there is enough tension to allow the rockers to pivot. Also how tight should the springs top nut be. Locktite at a certain torque or bottom the acorn nuts out letting the spring pack act as a lock washer? Thanks for any info or opinion.
    Dec 2012
    Santee
    Newfie
    On the rocker bolts, be sure to use self locking nuts, IE, Nylocks. and on the torque if using self locking nuts add the running torque to the amount of torque value you use.
    Ray
    2017 Harley Triglide
    Tijuana Border
    450+ Posts
    Mar 2018
    Fernley
    On the Chopper handbook site, well setting the rocker torque for a lock nut and a acorn nut is 150ft lbs.
    The rocker is suppose to have just enough play in it so it rotates freely on it's own. No tire on it and pull rocker up and watch it fall downward. Should be a slow easy movement. They make spacers for shoulder bolts for this reason among others.
    The rocker movement is not set by how much torque you apply, it is a calculated free movement using spacers, the torque settings are to hold the nuts on the bolt at a set position. It is how I understood it all.
    Hope you the best with this.
    50+ Posts chopptrk's Avatar
    Mar 2016
    louisiana,usa
    Tighten the rocker bolts to allow movement without any binding/sticking, nylon or brass washers between moving parts (no paint). Loctight (blue) or cotter pin. (my older set had cotter pins) A lil siff is ok, a lil loose is not good. The bumps will make it work, check again after a few miles.
    Top cap nuts on top of springs can be tightened all the down with a lil loctight. My old set had a regular nut then cap nut to lock, (double nut). My new set has cap nuts only.
    my 2 cents, hope it helps
    Sep 2018
    Thanks for the info. Got it back together everything went smooth. LOL. Here is a Couple of Photos of the front and the rim. Rim needs a bit more TLC. Got to disassemble it again. Messed up and gave it few scratches. So it is good training on how to lace and true a painted wheel and spokes. Had got it to a 1 mil (+/-) runout both ways.
Size:  816.2 KBName:  IMG_0678.jpg
Size:  739.8 KBName:  IMG_0681.jpg
Size:  835.9 KBName:  IMG_0749.jpg
    Sorry for the sideways photos. They turned when I uploaded. Got to figure out how to correct that. LOL.
    Mar 2021
    Phoenix, az
    Default What make/type of springer is that?
    Do you or anyone else on this forum know the make/manufacturer of that Springer? It looks real nice!
    Thanks!
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    At first glance I though china ebay.
    But after looking more closely it is not. Even though it is simply made it is also well made. For instance the rocker pivots are machined billets.....not just a squished tube with a hole drilled in it.
    The springs are mounted lower than a fork for for a 2 wheeler would be and the rockers are longer also.
    So I am gonna say it is a custom built specifically for a trike. Quite possibly by one of the long defunct custom builder outfits.
    The probability of being able to purchase one, while not zero.....is approaching zero.
    The chances of finding a custom trike shop to build one is slim, but possible.
    The chances are much higher of you building one yourself to fit your needs.
    Maybe someone knows where to purchase something similar. But as a trike needs considerable less trail and a more robust design......and all tailered to a non production frames geometry it is unlikely any production unit is going to be correct.
    Sep 2018
    The Trike is a Stires Stallion Flat Back by Custom Trikes out of Cali. manufactured by Claude Stires out of Cali till 86 . i can't find any history of who owned it next. Trying to build a history of the trike .
    Sep 2018
    Sorry. Of the Company. Not the trike itself.
    Quote Originally Posted by Lost Newfie View Post
    Companies that do title searches can probably for a fee get that info for you....
    May 2022
    Jacksonville,IL 62650
    Default Rockers
    How did you take and spacers/ bushings out I have a Stires and my springer front needs torn down and painted or polished up but it’s made of square rod and don’t want to flex the ends to drive out
    Quote Originally Posted by Happy_89 View Post
    Happy’ Welcome to Trike Talk…👍👍..
    400+ Posts
    Feb 2020
    Washington Pa USA
    Welcome to the talk . Good looking spring get end
    850+ Posts vwbug72501's Avatar
    Apr 2015
    Batesville, AR. 72501
    Here's some info that might help:
    http://scottymoore.net/MC75SCStingerTrike.html
    https://www.yellowpages.com/memphis-...-cycle-9830514
    Supercycle was a big Stires dealer back in the 70's. Ron and Lew were the business guys and Shack was the resident mechanical genius. They're probably all gone now as I am 74 and they were a little older than me. I did a couple of projects with Shack back in '72. Don't know if the shop still exists but it is still listed on the Internet Directories. If there is someone "younger" there still you might be able to get some info on the springer.
    Just checked Google street view...Supercycle logo is still on top of building but shop isn't there anymore.
    I have a Stires catalog from '72. If I can find it I'll scan it in and post it here.
  1. Springer front forks
    By grandpanystrom61 in forum VW Powered Trikes
    Last Post: 11-24-2018, 08:16 PM
  2. Springer Front End
    By drumdoctor in forum Home Built Trikes
    Last Post: 12-26-2013, 10:10 PM
  3. Springer Front End
    Last Post: 02-02-2012, 03:34 AM
  4. springer front end size
    By donnie850 in forum Home Built Trikes
    Last Post: 01-31-2012, 01:35 PM
  5. Frankenstein Trike kit on a softail springer
    By Pup in forum Harley Trike Conversions
    Last Post: 07-02-2011, 02:38 PM
