Likes Likes:  2
Results 1 to 5 of 5
Thread: problem with primary chain adjuster
    750+ Posts
    May 2011
    peru,in,usa
    Default problem with primary chain adjuster
    triGlide has 37k. on it .anyone having problems with OEM primary chain adjuster? whats the best manual adjuster. installed a new bolt in the screaming eagle compensator which had a shoulder on the bolt that the old one didn't have.
    1.59 from dealer. it had blue locktight on it. so i put 2 drops of red on the inside of the blue; and torqued it to 170 ft. lbs.
    just bought a open box with no instructions
    need install instructions for DRAG solid sprocket compensator
    p/ 1120-0390 vn 191200
    started the bike up ad the p/ chain flops wildly. just over 3/4" slack. it was 1/4" when i removed the primary cover.thanks leon
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    You don't state what year your referring to, but the compensator & cam chain adjuster have been a problem for years.
    Have you tried using your GOOGLE machine as there are a bunch of instructional videos on YouTube.
    Here's 1 link of many from the guys at Fix My Hog addressing the problem:
    https://www.fixmyhog.com/post/in-the...hain-adjuster/
    More info from you would be a plus in helping you address your problem
    See below link for the sprocket info you want
    https://asset.lemansnet.com/gen/part.../246337_V1.pdf
    750+ Posts
    May 2011
    peru,in,usa
    Default chain afjuster
    installed Drags compensator and a manual primary chain adjuster. 2009 trGlide
    still pretty noisey, but haven't driven it only 5 miles so far. need at least 100 miles and its suppose to quieten down
    Oct 2010
    USA
    Check Baker Drivetrain for a primary adjuster.
    Your chain all stretched out and your maxed out on your adjuster?
    Is the block worn out?
    How many teeth were on the compensator versus new??
  1. Primary Chain Tensioner
    By DamnYankee in forum Harley Tri Glide
    Last Post: 03-19-2018, 08:20 AM
  2. rear suspension adjuster
    By Sand Piper in forum Honda Trikes
    Last Post: 10-28-2015, 08:50 AM
  3. Baker Attitude Adjuster
    By jwkhd1 in forum Harley Tri Glide
    Last Post: 09-14-2015, 08:34 AM
  4. primary chain adjustment
    By engprosinc in forum Harley Trike Conversions
    Last Post: 06-20-2013, 03:03 PM
  5. Chain adjuster on swingarm.
    By BIBS in forum General Discussion
    Last Post: 11-08-2010, 11:56 AM
