ctdair7Jack KlarichHarley Tri GlideHot Rotors After New Pads
Speed Bleeders
Likes Likes:  35
Thanks Thanks:  5
Page 2 of 2 FirstFirst 1 2
Results 21 to 39 of 39
Thread: Thundervolt 50 Spark Plug Wires...Simply Amazing.
  1. #21
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Quote Originally Posted by Tucci View Post
    Does the tank need to be raised to change front plug wire
    Tucci, I've never changed plug wires on a twin cam. On the M8, the 4 wires are tie wrapped to the frame at various locations.
    You have to remove the tank to do it properly.
  2. #22
    200+ Posts
    Sep 2018
    Pa
    Default Wires
    Jack/Michael thanks. On the 15 fw, is changing out the wires worth the hassle. I was only going to do plugs. 26,000 on odom
  3. #23
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    To make changing the wires easier pulling the tank is a plus, at least on my Freewheeler it made it easier
    Not a hard job to pull the tank
    What is the trick on detaching the gas line. I push up on the collar and the gas line will not come loose. Do I rotate the collar until it clicks than push or what?
    I had this tank off before but I be damn if I remember how removed the gas line!
    HOW CAN YOU HELP THE TRIKE TALK FORUM? Become a GOLD CLUB MEMBER!
    A veteran - whether active duty, retired, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to the 'United States of America', for an amount of 'up to and including my life.'
  4. #24
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by nucseal View Post
    Lift up on the collar and pull down on the plastic line, they are a tight fit
  5. #25
    Oct 2017
    St. Louis, MO USA
    I put a rag behind the fuel line quick disconnect & spayed a shot of silicone on it. They can get a little crusty after sitting a few years.
  6. #26
    Oct 2017
    St. Louis, MO USA
    After what I learned recently, I would. You have 26,000 miles on wires that were most likely out of spec. in the 1st. place.
  7. #27
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Joe, if you buy good wires and route them good you will be money ahead
  8. #28
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Tried that. Didn't want to budge. If tried it on a friends bike and had the same problem. Has to be something I am doing wrong. Scratching my head on this one and frustrated.
  9. #29
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Tried that. Didn't want to budge. If tried it on a friends bike and had the same problem. Has to be something I am doing wrong. Scratching my on this one and frustrated.
    Try a shot of silicone lube, rotate the plastic line a bit while pulling down
  10. #30
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    And pull straight down from the quick release. Even a bit of an angle on the pulling down will bind it up.
    www.DKCustom.com
  11. #31
    200+ Posts
    Sep 2018
    Pa
    Default Silicone
    Quote Originally Posted by MDO View Post
    Nice tip about the silicone. I was having a tough time moving the chrome fitting. Sprayed it, rotated several times, it lifted up and the hose just about fell off!
  12. #32
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Thanks guys. Will try that once I get back in town! Am out of town for the next week.
  13. #33
    200+ Posts
    Sep 2018
    Pa
    Default Dual plug
    On the 2015 Freewheeler, does the tank need to be removed or is there enough room to change front wire by loosening the front and rear mounting bolts
  14. #34
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    No removal needed on my 15 Freewheeler
    The 17 M8 it is a must
  15. #35
    200+ Posts
    Sep 2018
    Pa
    Default Tank removal
    Jack, your are fountain of knowledge! Now one more question. You said you used hd plugs. Regular 6r12 or did you go with the screaming eagle 6r12g
  16. #36
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Stick with stock plugs
    The reason I say this is
    1. your TC engine has Delphi Ion Sensing designed into the ECM
    2. changing to a plug with a different resistance will cause the ECM to read this signal as much as being out of spec, this could cause timing issues and up to including a trouble code
    3. stock plugs are cheaper and your engine was designed to run with them
    I have tested and run many plugs on many HD engines, I always come back to stock
    Read here
    https://www.triketalk.com/forum/thre...ey-Ion-Sensing
  17. #37
    200+ Posts
    Sep 2018
    Pa
    Default Ion
    Read here
    Completely mind boggling. I'm coming from the stage coach era into total computerized, concerning engines. Without someone with your experience on this site i could very well see a massive amount of money being wasted on repairs/shop hours on simple things like this(spark plugs etc)
  18. #38
    Oct 2017
    St. Louis, MO USA
    Tucci, I stayed with the stock plugs on my M8(6R10) After 2 years, they looked very good and all 4 were identical.
    With my 10% Veterans discount at my dealer, they were $19 & change for 4. I can handle that every few years.
    I was gonna try NGK, but I ended up getting the wrong tip & it was a big hassle that was not worth it to save $8.
  19. #39
    200+ Posts
    Sep 2018
    Pa
    Default Ion research
    The site Jack referenced was an eye opener in that ,one "small" variable in the electrical/ignition system on the newer engines can cause an untold amount of problems. And i'm sure you know, when it comes to electrical gremlins you're in limbo
  1. changing plugs and plug wires
    By Doc7402 in forum Stallion Trikes
    Last Post: 02-05-2019, 03:10 PM
  2. Spark Plug Wires
    By RAHRAHJR in forum Harley Tri Glide
    Last Post: 04-08-2018, 04:31 PM
  3. speaker wires in multi pin plug
    By oneup in forum Harley Trike Conversions
    Last Post: 05-25-2016, 01:48 AM
  4. Spark Plug Wires
    By FuzzyWuzHe in forum Harley Tri Glide
    Last Post: 05-01-2015, 02:29 PM
  5. Need Spark plugs and wires...please provide brand ETC
    By starrtrain in forum VW Powered Trikes
    Last Post: 05-17-2014, 08:33 AM
