Thanks Thanks:  1
Results 1 to 5 of 5
Thread: LED Indicators
    Oct 2015
    Sherman Texas
    Default LED Indicators
    Has anyone tried to replace or modify the battery voltage and air pressure LEDs to make them more readable in daylight conditions. I haven't found a good solution?
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    Quote Originally Posted by KE5WL View Post
    After 10 years and 77k miles, I'm really not seeing the need as you indicated. Unless the sun was coming over my shoulder I don't recall having a issue that placing my hand over the gauge to block the sun didn't help see the readout. You could make a shade cap but then again I don't think it would completely do what you want because of the different sun angles hitting it. But if you do find a solution, take photos and post it for others and good luck. Tomg
    Oct 2015
    Sherman Texas
    How stupid of me for asking then.
    200+ Posts
    Feb 2017
    Arp, TX - USA
    Other than what was mentioned above the only other thing you can do would be to have a new lens made without the "tinting". The tint is in the plastic lens and is not something that's put on the lens after production.
    You MIGHT be able to take thick piece of clear lexan/etc & make your own in place of; but if you remove the lens on the Stallion you'll see that it's also not quite so simple because of the "tabs" it has molded into it for mounting. Not to mention your trim lines probably won't be as smooth as the ones on the lens now (I think the ones used are trimmed/cut robotically).
    Oct 2009
    Titusville, Florida
    Your question was NOT stupid as you were just asking if others experienced the same issue and what they did to correct it. This is what the forum is about , answering questions and helping others!
    Tomg
  1. Riding a well maintained Wing - maintenance indicators
    By GoldWingrGreg in forum Honda Trikes
    Last Post: 08-21-2017, 10:20 AM
  2. Warning Indicators/ diagnostic self test question!
    By mozrocks in forum Yamaha Trikes
    Last Post: 06-28-2015, 07:36 PM
  3. LED Lights
    By katfish16 in forum Accessories
    Last Post: 09-08-2010, 07:26 AM
  4. goldwing turn indicators
    By 5thwheel in forum Honda Trikes
    Last Post: 07-10-2009, 10:08 PM
  5. Need Review - Show Chrome LED Tail Lights
    By patriot in forum Accessories
    Last Post: 08-11-2008, 09:51 AM
