Phu Cat3cScjhbGeneral DiscussionIs there a TV commercial
Phu Cat3trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat3Phu CatGeneral DiscussionIs there a TV commercial
Likes Likes:  4
Results 1 to 13 of 13
Thread: Champion Raked Trees
    90+ Posts
    Oct 2018
    Linden, TX
    Default Champion Raked Trees
    I am attempting to adjust my steering head bearing play. Setup is different than stock. Have a hex bolt with tall black spacer. Below spacer is a thin bName:  20190625_124933.jpg
Size:  561.4 KBlack nut. Hard to get off...very hard. If/when I remove this, will it give me access to the steering head adjustment nut below, or is there another procedure for adjusting. A little loose on the steering.
    90+ Posts
    Oct 2018
    Linden, TX
    It is their EZ Steer kit for HD '87-'01 .
    90+ Posts
    Oct 2018
    Linden, TX
    Already been to Champion Resourse Center. Mine is early model. Not mentioned.
    90+ Posts
    Oct 2018
    Linden, TX
    Shots of upper and lower...lotta wires on an Ultra.Name:  20190625_145645.jpg
Size:  514.0 KBName:  20190625_145625.jpg
  6. #6
    Apr 2010
    Shenandoah Valley of Virginia
    Someone was from that school that says "never use a wrench or socket when vise grips will fit"?
    My guess is that knarly black nut is the one to torque, then the spacer and bolt locks the top tree to stem … maybe? Is the "spacer" hollow and covers that nut?
    Papa Zook will let us know soon?
    Make Courtesy Your "Code of the Road" too!
  7. #7
    90+ Posts
    Oct 2018
    Linden, TX
    Yes, the spacer is hollow. Would get great satisfaction kicking engineer's butt who designed the radio mount.
  8. #8
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Yes that is an early model. Look under the center of the bottom tree and see if there is a nut or allen head hole in the middle of the lower steering stem shaft and post back. You're also more than welcome to call me at 346-800-7946.
  9. #9
    90+ Posts
    Oct 2018
    Linden, TX
    Quote Originally Posted by Papa Zook View Post
    Torrential downpour here in East Tx right now, will look when I can. Thanks. Ken
  10. #10
    90+ Posts
    Oct 2018
    Linden, TX
    Break in weather. Dual brake line manifold screwed to underside with 2 spacer washers. Will unfasten and look under washers if and when it stops raining. 5 1/2" since 3am. KenName:  20190629_163348.jpg
  11. #11
    90+ Posts
    Oct 2018
    Linden, TX
    Brake line manifold off. T40 5/16" screw holding manifold appears to fasten to bottom steering stem, which protrudes @ Name:  20190630_102821.jpg
Size:  437.0 KBbottom with large circlip retainer.
  12. #12
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Thanks for the pics. That is where you tighten/torque you steering stem while holding the top nut. Using a jack under the frame, raise the front of the bike so that the tire is 1 inch off the ground, then torque the steering stem from the bottom to 40 ft lbs, briskly turn the font end back and forth left to right, lock to lock. It should have just a bit of resistance, but not too much. But before you tighten it at all, what does the resistance feel like? Does it just easily flop side to side?
  13. #13
    90+ Posts
    Oct 2018
    Linden, TX
    Think I found my floppy handling problem. Had a growl start in front hub, so did a wheel bearing kit today. One bearing fell out in several pieces...dont know how it even kept rolling.
    Handling is now how it should be.. .no more wandering on the road. Thanks for all the help...the problem presented at the right time
    Thanks. Ken
  1. Replies: 6
    Last Post: 02-26-2016, 12:12 AM
  2. raked trees
    By hddog in forum New Member Introductions
    Last Post: 02-02-2015, 10:13 AM
  3. Front fender angle with raked trees
    By riderdave in forum Harley Trike Conversions
    Last Post: 08-15-2014, 12:40 PM
  4. Raked trike trees "again"
    By bluerim in forum Harley Trike Conversions
    Last Post: 05-11-2013, 01:07 PM
  5. how did you convert front fork air system on raked trees
    By pcombe in forum Harley Trike Conversions
    Last Post: 04-22-2013, 07:46 PM
