Likes Likes:  4
Results 1 to 11 of 11
Thread: Rear Axle Seals
    30+ Posts OntarioLes's Avatar
    May 2019
    Napanee, Ontario Canada
    Question Rear Axle Seals
    The Lehman Trike on my 2008 Suzuki C50 requires seals for the rear axle. The trike serial number T003182. Does anyone know what seal would fit this rear axle? I have heard the Lehman used Ford rear axles for some trikes until they developed their own based on the Ford design. I hope the seal is a popular style that I will be able to source locally in Ontario.
    OntarioLes
    Eastern Ontario
    1990 Honda Gold Wing Trike
    5250+ Posts Pegasus1300's Avatar
    Spring City,Utah, USA
    If you can get the seal out take it to a bearing house and they can match it off the numbers on the seal.
    Happy TRAils/NSD
    Paul
    May 2019
    That's a great tip! Was hoping the numbers might be readily known.
    Thanks for your quick reply!
    OntarioLes
    Eastern Ontario
    William give the post a day or 2 to be read. Jim our Lehman guru should catch your post soon.
    Apr 2010
    Shenandoah Valley of Virginia
    2008
    Just as a starting point, these #s might help when looking them up at the parts store, they are for Ford 6.75 axles … like my older GTL uses. National #3214 or NAPA #13985
    May not even be close.
    I think Jim told me once that later on, they switched to a different axle so these numbers may be useless.
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Cool
    Quote Originally Posted by OntarioLes View Post
    Les,
    The 3214 National seal is the right one for your axle.
    About seals .... I have found that inexpensive seals may stop leaking short term but are not as resistant to early failure. So it is best to find a National or Timken seal. If your seal is leaking, the grease may have been washed out of the sealed axle bearing as well. This too might need replacement. If so, it is best to do both sides at the same time.
    Jim Murphy
    Iron Butt Rider 2001
    May 2019
    Thumbs up
    Superb! Thank you Jim and all who replied! This forum has been the most reliable source of important details about Lehman trikes!
    I will be checking the bearings while doing this job.
    OntarioLes
    Eastern Ontario
    Martinsburg, WV
    Cool
    Les, If the bearing spins freely (like it is lacking grease and sounds dry) replace them.
    Given your location, Do not use the Chinese made bearing.
    I have had very bad results in 10% of the ones I have used in the past.
    I only use Japanese bearings now and have sold over 100 without an issue.
    Jim Murphy
    May 2019
    Thumbs up
    Jim, I have ordered seals. I spoke with Canada Bearing today - Believe it or not National doesn't have any stock in CAN or US for 3214. However, that number crossed to 13985 from Chicago Rawhide. Apparently only available in the US although this is an SKF number. Will search deep if the bearings need replacing.
    Thank you!
    OntarioLes
    Eastern Ontario
    Martinsburg, WV
    Cool
    Thank you!
    I have a dozen on my shelf, but am also having difficulty getting them too.
    I also have the Timken Bearings (Made in Japan) in stock but they are being used up quickly.
    If you need unavailable parts, www.mjtrikes.com and call me after 9am eastern.
    Jim Murphy
    May 2019
    Jim - simply - Thank you!
    OntarioLes
    Eastern Ontario
  1. Motor Trike Axle Seals
    By Judge Judy in forum Honda Trikes
    Last Post: 08-04-2016, 08:27 PM
  2. Solid Axle vs Independent Axle
    By vbbuilt in forum Harley Trike Conversions
    Last Post: 09-15-2014, 11:53 AM
  3. Harsh ride, leaking seals & anti-dive
    By Muleskinner in forum Honda Trikes
    Last Post: 11-01-2011, 11:24 PM
  4. frt fork seals
    By glennbo59 in forum General Discussion
    Last Post: 04-17-2011, 05:41 AM
  5. seals leaking
    By 01winger in forum Miscellaneous
    Last Post: 11-24-2010, 09:21 PM
