Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  6
Thanks Thanks:  3
Results 1 to 15 of 15
Thread: Thunk in area of right rear wheel
    80+ Posts
    Oct 2015
    Foresthill, Ca
    Default Thunk in area of right rear wheel
    I have a noise in the right rear wheel area that I first thought was something in the tire but nothing was found. It has gotten louder and I am at loss to what is causing the noise. It sounds like a Thunk and doesnt do it every revolution of the wheel but it does do it quite often. I almost sounds like something is knocking on the fender down low. I had some friends listen and look at it and they thought it was a u joint. I checked the driveline u joint (2014 Champion IRS kit on my 2007 Goldwing) and found it was in fact failing so I replaced it. Noise is still there. I am wondering if the cv half shaft would make such a noise? I have about 30 thousand miles on the conversion. Any ideas? I am willing to check them all out. :0) Thanks!
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    Check where the sway bar is attached to the frame.Not the end links but the actual mounts on the frame.I saw both break once and the bar could be bumping against the frame while your moving.
    1989 GL1500 Goldwing (SOLD)
    2006 GL1800 CSC
    80+ Posts
    Oct 2015
    Foresthill, Ca
    Thanks Marc! I will definitely give that a look over. Thanks for taking the time to reply to my question.
    80+ Posts
    Oct 2015
    Foresthill, Ca
    Quote Originally Posted by bcop31 View Post
    After checking further, I have determined that the clicking noise (I said thunking noise but it is more of a deep clicking sound) is coming from the outer CV joint on my half shaft. I have ordered up a replacement from Champion so, with the help of a good friend of mine, we will replace the cv half shaft and should be good to go. I haven't replaced one before but it doesn't seem to be to difficult. Guess Iwill find out.
    't
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    't
    Take your time and think it through and you won't have any issues.
  6. #6
    80+ Posts
    Oct 2015
    Foresthill, Ca
    Well, I ordered up a new CV short shaft from Champion for my trike and, with the help of a friend, put it on today. Less than an hour to take the old off and install the new one. Pretty easy! When it was time to pull the old one off, I pulled on the shaft and felt it separate inside the upper boot. We cut the boot open and found that the keeper for one of the round bearings had failed which allowed the shaft to knock around. gulp! Anyway, all back together and no clicks or thunks! Now to make up some of the riding I have been missing!!
  7. #7
    Dec 2014
    Grand Junction, Co. USA
    Congrats on the fix.
  8. #8
    Gone But Not Forgotten
    Tech Contributor
    Lee H. Mann's Avatar
    Apr 2011
    Martinsburg, WV
    Glad you got it squared away......
    Jim Murphy
    Iron Butt Rider 2001
  9. #9
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Apples to Oranges here.......But here gos... I was getting a Thunking coming from the rear tire on my Slingshot, When i stopped to check it out, I realized i had run over my neighbors cat....
    [Bobs evil twin is at the keyboard again]
    2019 Tri-Glide.......
  10. #10
    350+ Posts 3W-lonerider's Avatar
    Feb 2008
    Shippensburg, Pa
    back when i was driving truck, i had a thunk in the left front wheel. seems i hit a skunk and threw him up around the wheel well and fender a few times before he go spit out.
    had to smell that sucker for a week.
  11. #11
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    Do you have before and after pics....
  12. #12
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Quote Originally Posted by trikeman View Post
    The Coyotes took it away .........
  13. #13
    Oct 2010
    Without pics it didn’t happen...
  14. #14
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Coyotes aren't equipped with opposable thumbs, And as such can not operated a camera so no pictures are available... ......
  15. #15
    Oct 2010
  1. 16x5.5 inch rear wheel converted to dual dics front wheel
    By irmagoo in forum Tires, Wheels, Brakes, Front End
    Last Post: 01-15-2022, 08:29 PM
  2. Replies: 42
    Last Post: 05-21-2018, 08:03 AM
  3. Front Wheel--Rear Wheel
    By drumdoctor in forum Tires, Wheels, Brakes, Front End
    Last Post: 08-06-2015, 12:45 PM
  4. Replies: 5
    Last Post: 12-08-2013, 08:01 PM
