AriNV4Pegasus1300Rider Safety Discuss...Maybe silly but serious question, s...
AriNV4cycle7447Rider Safety Discuss...Maybe silly but serious question, s...
AriNV4Jack KlarichRider Safety Discuss...Maybe silly but serious question, s...
AriNV4AriNVRider Safety Discuss...Maybe silly but serious question, s...
Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
ken g9Old Road DogHarley Tri Glidereverse not working
Likes Likes:  17
Thanks Thanks:  3
Results 1 to 20 of 20
Thread: cooling fans never seem to come on
    10+ Posts
    Feb 2018
    Sparta Mi usa
    Default cooling fans never seem to come on
    I have a 2015 trike mostly stock and when I bought it new the cooling fans seemed to run most of the time when I shut it off but recently the fans never seem to come on. We were riding in 90 degree weather and normally the fans would kick in but not now. I have tried them manualy and they do work what else could it be.
    Dec 2014
    Grand Junction, Co. USA
    Quote Originally Posted by halvander View Post
    Are you talking about the stock cooling fans or an after market. When you say tried them manually, what does that mean? I'm not aware of a way to turn the stock ones on manually. Did you check the fuse for the fans?
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    I would think that, like most cooling fans, they are thermostatically controlled. I would, after checking the fuse as Fuzzy suggests, jumper out the thermostat & see if they run & if they do, remove/replace the thermostat.
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Try this to see if both fans come on
    Turn your bike on, don't start it, then roll the throttle half way and the pump and fans will come on. This feature lets you check everything works and helps get the air out if you ever have to drain and refill the system. Pump and fans run until you turn the ignition back off.
    300+ Posts
    Dec 2014
    florissant
    When my trike was new they ran alot too. After breaking it in and installing vied's and killing the cat they hardly ever run anymore.
    hardheaded
  6. DKCustoms postbit
  7. #6
    Dec 2014
    Quote Originally Posted by headheaded View Post
    Yep ... since tuning, de catting. mighty mites, tank lift, air deflectors, mine haven't come on ... hmmm ... might have to try Jacks tip to see if they still work ... LOL. Good tip Jack.
  8. #7
    150+ Posts KJB's Avatar
    Oct 2014
    NE WI & SW FL
    That's amazing. I just went out in the garage and gave this a try. Sure enough the fans came on. Thanks for sharing.
  9. #8
    600+ Posts ISP-FL's Avatar
    Mar 2017
    Lake Suzy, FL USA
    Yes, thanks Jack, that is good info to know!
    Current: 2019 Trike (custom 130ci T-Man kit with Darkhorse bottom end)
  10. #9
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Maybe this could be a sticky?
  11. #10
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    This is one of many reason this site is so great,the wealth of knowledge here is amazing.
  12. #11
    10+ Posts
    Feb 2018
    Sparta Mi usa
    I have done this and both the pump and fans come on, another trike owner said it could be the pump going out as he has replaced 3 on his 2016
  13. #12
    Dec 2014
    At least we should make a sticky to put some of these tricks in. The cruise control diagnostic was a good one too.
  14. #13
    Oct 2017
    St. Louis, MO USA
    Did you check the thermostat? Doesn't it control the fans coming on?
  15. #14
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Have you checked for any DTC? Is your trike running hot?
    Is your coolant low?
  16. #15
    10+ Posts
    Feb 2018
    Sparta Mi usa
    coolant is right up there and its doesn't seem to running hot, not sure how to check the thermostat
  17. DKCustoms postbit
  18. #16
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Has your coolant light or engine light come on and stayed on?
    Have you checked for stored codes?
    Harley claims few issues with their thermostats, saying more often the pump goes bad
  19. #17
    Oct 2017
    St. Louis, MO USA
    Jack, doesn't the thermostat control the fan coming on? Please correct me if I'm wrong.
  20. #18
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by MDO View Post
    I am not sure how it works with the engine coolant temp sensor, I have not had the displeasure of working on one of these systems
    I would think if one was having problems with one of these there should be a trouble code and or an engine light on
  21. #19
    10+ Posts
    Sep 2019
    akron
    I have the same bike, same trouble. Works fine when manually turned on.
  22. #20
    800+ Posts woody's Avatar
    Jul 2012
    Talladega,Al 35160
    Pump, if the pump has not been changed out it is probably the pump. Put your hand on the pump and do the throttle trick to see if it starts. Mine would run sometimes and other times it would not. The Magnetic coupling was
    Cracked and sticking or binding.
    Name:  2014 TriGlide Waterpump (4).jpg
    2019 Goldwing CSC
  1. Cooling Fans
    By hotrodbob in forum Harley Freewheeler / Road Glide 3
    Last Post: 05-10-2016, 09:41 AM
  2. HD cooling fans
    By Lakeman in forum Harley Trike Conversions
    Last Post: 03-02-2015, 04:05 PM
  3. Cooling Fans
    Last Post: 02-17-2015, 01:13 PM
  4. Cooling fans
    By bigjim54 in forum Harley Trike Conversions
    Last Post: 02-02-2014, 05:00 PM
  5. wards cooling fans.
    By flatfrog in forum Harley Trike Conversions
    Last Post: 09-26-2013, 02:32 PM
Tags for this Thread
