Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  7
Thanks Thanks:  1
Results 1 to 11 of 11
Thread: No stop lights
    200+ Posts
    Nov 2016
    groesbeck texas usa
    Default No stop lights
    Neither one of my brake lights come on using hand or foot. Ipulled both rear bulbs and am not getting juice to the brake light pin. Any ideas?
    Dec 2013
    Clarion PA USA
    Quote Originally Posted by lightnin View Post
    check the fuses and look for a bare wire good starting point good luck Fred
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    I would run a diagnostics check first
    Look Here https://dgcustomcycle.com/tech/harle...es-04-present/
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Are the running lights operating? Also, please update your profile...It's hard for someone to help you when they don't know what your riding.
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Thumbs up
    Quote Originally Posted by MDO View Post
    Along with what year your bike is maybe a bit more info like any recent modifications and have you any DTC present will be a good starting point
  6. DKCustoms postbit
  7. #6
    1500+ Posts
    hardwickbv's Avatar
    Mar 2017
    Mitchell, Indiana, USA
    I had work done on mine and had the BCM changed out then found out that the BCMs are set up for two wheel bikes and there are several setting that have to be changed for Trikes
    Reverse and brake lights are a couple of them.
    The dealer recognized the reverse issue right off the bat but I rode it for a couple days before I notice the brake lights not working (tour pack brake light worked) and my spare key FOB would not work.
    Had to take it back in.
    I also believe that the green light on the Tach for the auxiliary lights is controlled by another setting as it hasn't been on since I had the work done but since the switch has a light on it I like it better that way.
  8. #7
    150+ Posts David792's Avatar
    Mar 2019
    Idaho Falls, Idaho, United States
    I'm not suggesting that this is your problem, but just to illustrate how funky fuses can be: I have a 2018 and on a trip back from the shop my aux headlights and tour pack trim lights stopped working. I went over that motorcycle from top to bottom before I discovered that the battery tender pigtail fuse was blown. I replaced that fuse and everything works again. Magic!
  9. #8
    200+ Posts
    Nov 2016
    groesbeck texas usa
    I need to check the tender fuse, thanks mine is a 2016. Installed the rear LEDS, they bright, run works and so does turn signals but no 4 way flashers or brake lites either front lever or foot pedal. When I ran the codes it came back rear brake light switch and BCM. Bought the switch then figured out there's no way my old azz can change it, shop bound. Going to install my LRS 13" flat top today, I think I'am going to like it.
  10. #9
    Oct 2017
    St. Louis, MO USA
    I'm confused. Changing your tail light bulbs to LEDs does not make your rear brake light switch quit working.
    Good luck.
  11. #10
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Good luck.
    Strange both brake switches not working @ the same time?
  12. #11
    200+ Posts
    Nov 2016
    groesbeck texas usa
    that's what I'am thinking Jack. It's going to a friend of mine's shop the end of this month. I'am too old to be crawling around on the ground.
  1. “Stop Sales Stop Riding” Recall Ban ???
    By Keystone in forum Polaris Slingshot Trikes
    Last Post: 02-16-2015, 02:47 PM
  2. Stop That Slipping Clutch
    By 1550vt in forum Harley Trike Conversions
    Last Post: 08-12-2013, 01:26 PM
  3. Tripping stop lights
    By Phu Cat in forum Harley Trike Conversions
    Last Post: 07-28-2013, 12:19 AM
  4. How to stop the rattle in the front end.
    By Heart Stoppper in forum Stallion Trikes
    Last Post: 04-11-2012, 12:36 PM
  5. HD to stop building side cars
    By ultraboy in forum Harley Trike Conversions
    Last Post: 08-01-2010, 11:08 PM
