Likes Likes:  13
Thanks Thanks:  2
Results 1 to 14 of 14
Thread: 2019 Harley Triglide Hydraulic Clutch Problems
    1+ Posts
    Jul 2019
    Elyria, Ohio, USA
    Angry 2019 Harley Triglide Hydraulic Clutch Problems
    I have a 2019 Triglide with less than 5k miles on it. Recently my clutch started acting up. Did have a 1k service done and also had it back to the dealership recently when the clutch started acting up. Rode it all day yesterday - no problems. Back it out of the garage today and rolled it onto the street. Started off okay! Got to the beginning of the development I live in and suddenly no clutch. At first when it stalled I thought that maybe I forgot to down shift but then I realized that as soon as I began to let off a little pressure off of the clutch handle it lurched forward. Didn't feel any resistance from the clutch handle at this point. Squeezed the clutch handle about 30 times until I felt a little resistance and I was able to nurse it all the way back to the garage. Dealership said that they examined the clutch and everything looked good and they bled the clutch lines. Worked for a day or so then started acting up again. Anyone else experiencing any problems with their hydraulic clutch??
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Tony Welcome to Trike-Talk...........I can't help on your clutch problem, But i'm sure someone will chime in soon and be of help.....
    2019 Tri-Glide.......
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    It surely sounds like you have a pressure problem related to a master cylinder or clutch actuator leak
    Call your dealer, have them come and pick it up. It cannot be trusted to ride it now and it is under factory warranty
    Welcome to Trike Talk
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Quote Originally Posted by Puckmeister View Post
    Welcome from Missouri.
    It sure sounds like air in the lines, low brake fluid, maybe a defective secondary clutch actuator/seal problem. That is what was happening to some 17 & 18 models with hydraulic clutches prior to the recall to replace the actuators with updated units.
    Either way, that is totally unsafe to operate in that condition & your dealer should not have let you ride off like that.
    That is a safety/warranty issue & I would demand it be repaired immediately.
    I have a 17 Freewheeler & it was not loosing fluid/acting up, but after the recall it definitely had improved clutch action.
    There is a company called AIM that makes an improved hydraulic actuator with reduced clutch pull of 40% but you should not have to pay anything while under warranty, plus the MoCo would void your warranty with an aftermarket clutch part. As you well know, you payed enough already.
    Keep us posted with your outcome on your issue & good luck!
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Tony, Harley has been having problems with hydraulic clutches for a number of years
    Their last recall for 17-18 models was supposed to have fixed the latest problems
    Your 19 model should have the upgraded parts on it depending on the build date of your trike
    That said as Michael already stated you NOW have a safety issue and your dealer needs to make it right for you
    Good Luck and keep us posted
  6. DKCustoms postbit
  7. #6
    2250+ Posts radismukes's Avatar
    May 2018
    Angleton, Texas
    To the Trike Talk Family! FROM SOUTH Angleton, TX
    Howdy Tony!
    “Come and Take It!” “Remember the Alamo!” “Remember Goliad!”
  8. #7
    1500+ Posts ShapeShifter's Avatar
    Aug 2018
    SW, Arkansas, USA
    Smile Hello!
    Tony, Welcome from SW Arkansas. Hope they get your clutch issue resolved quickly.
    2016 Tri Glide Billet Silver w/Pinstripes ["Hi-Yo, Silver! Away!"]
    • "There is so much good in the worst of us, and so much bad in the best of us, that it ill behooves any of us to find fault with the rest of us." ..... James Truslow Adams
    • 2nd BN 33rd Armor "The Tiger Battalion" "1972 - 1974"
  9. #8
    450+ Posts
    Dec 2018
    Perry, Georgia, United States
    Welcome to the forums from Middle Georgia Tony!
  10. #9
    150+ Posts prariepilot's Avatar
    Apr 2016
    North Ridgeville OH, USA
    Default Welcome!
    Welcome to TrikeTalk, Tony, from the other side of town!
    2013 Tri Glide Ultra Classic (FLHTCUTG) DK Oil Cooler/Relocation Kit DK Custom Tank Lift Kit DK EBS Kit K&N A/C in Stock Airbox Convertible Comfort Lift Kit w/ 14" Pro Action Shocks
    Vance & Hines Monster Ovals behind OEM decatted header Motor Trike Mechanical Reverse DynaJet Power Commander V
  11. #10
    Just Killing Time...
    paws's Avatar
    Oct 2011
    Kerrville, TX U.S.A
    Hi Tonyyyyyyy!
  12. #11
    Dec 2014
    Grand Junction, Co. USA
    Welcome to the Gang from Western Colorado.
    I agree with the others ... sure sounds like an air infiltration issue ... snd it sure a safety issue. Call the dealer, make them earn their keep.
  13. #12
    1000+ Posts
    Aug 2016
    Des Moines IA US
    Welcome from Iowa
  14. #13
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    welcome aboard
  15. #14
    650+ Posts
    Sep 2015
    Sheboygan, WI
    Welcome aboard, Tony, & enjoy the ride! Hope you get it fixed up soon.
    It is what it is.
    16 Tri Glide vivid black
  1. VW trike hydraulic clutch problems
    By Zar in forum VW Powered Trikes
    Last Post: 06-22-2021, 08:29 PM
  2. hydraulic clutch problems
    By grunt67 in forum Harley Freewheeler / Road Glide 3
    Last Post: 03-05-2018, 10:46 AM
  3. Replies: 10
    Last Post: 10-10-2017, 06:53 PM
  4. Hydraulic clutch too hard to pull
    By Huelshorst in forum Harley Tri Glide
    Last Post: 03-17-2016, 11:49 AM
  5. New Build Hydraulic Clutch/Brake Clutch Pedal Fabrication
    By usnavy8084 in forum Home Built Trikes
    Last Post: 10-21-2012, 08:18 AM
