Likes Likes:  3
Thanks Thanks:  11
Results 1 to 15 of 15
Thread: Stuck in Spearfish,SD
    TOI - New Mexico
    May 2010
    Aurora, CO
    Default Stuck in Spearfish,SD
    The right front bearing cover came off of my Stallion on the way to the 3 Wheel Rally. I’m here in Spearfish hoping an auto mechanic can fix the Trike. Hate to say this but, every motorcycle place could not help. Fingers are crossed,
    Good Luck, Might try a Ford Place, I believe it's a Ranger power plant.
    Most of the front end is Ford so any mechanic be able to work on it 🙏
    250+ Posts
    Dec 2010
    oly,wa
    did just the cover come off? does the seal look ok, if it is not spewing grease around it is probably ok. it is just a cover held on by allen screw. paul the tt coridnator in deadwood had his stallion worked on in spearfish but I don't know where. give him a call or see him at tt headquarters
    good luck
    Dragon
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    The dust cover on both sides of the axle are just that! You should see a nut with a carter pin through it which has a washer behind it and behind that is the seal for the axle and bearing. Both sides are the same. So if all is missing is the dust cover, ride on, you don't have any issue. Tomg
    250+ Posts
    Dec 2010
    oly,wa
    Good morning
    you might give outdoor motorsports a call 3245 e colorado blvd 605-642-7731 opeans at 9am hope this helps
    Dragon
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Call Pmar. (Paul) 605-520-7570 He is at the rally. His Stallion broke down last year or year before. He got a shop in Spearfish to tow it in & fix it... He is leading the TT TOI rides.
    Oct 2009
    Titusville, Florida
    I should further clarify that the swing arm is against the seal and caliper bracket which has the outer and inner grease seal as wel as the bearing. The outer cover is only a decorative cover for the axle nut and end of the axle. I have known many who were missing both axle covers. Tomg
    250+ Posts
    Dec 2010
    oly,wa
    Good evening
    was any of this helpful did you get going again. hope so too many things to miss
    Dragon
    300+ Posts
    Signal Mountain Tn
    Ditto Dragon's comment. I am of Paul Harvey vintage. I want to hear the rest of the story. Me thinks you just lost a dust cap. I did the locktite treatment to mine years ago.
    TOI - New Mexico
    May 2010
    Aurora, CO
    Well, no go on the mechanic so, I’m going to drive it back to Denver and hit the caliper seal with Lithium Grease every stop I make. I love the Stallion but, this lack of proper mechanical help is ridiculous! Time to start thinking about a trade.
    Oct 2009
    Titusville, Florida
    Quote Originally Posted by Pooh105 View Post
    Well, no go on the mechanic so, I’m going to drive it back to Denver and hit the caliper seal with Lithium Grease every stop I make. I love the Stalluon but, this lack of proper mechanical help is ridiculous! Time to start thinking about a trade.
    I don't understand why. Give me a call and maybe I can help you understand where things are as I've had mine apart a few times for tire replacement as well as other maintenance needs. Tomg 321 268 5889 home number
    Mar 2016
    Wadena
    Default Fix
    I had my front wheel bearing replaced in spearfish in 2015 on my 2008
    TOI - New Mexico
    May 2010
    Aurora, CO
    Default Made it back home
    All,
    Sorry for the long response time. I did make it home with no incidents. As TOMG stated, it is the outside dust cover on the right side of the front wheel. I had this same thing happen with my first Stallion. That repair place is now closed in Golden. Also, as TOMG stated, riding does not seem to have any effect or cause any damage. It just looks weird seeing that ring off the side.
    Again, I'm sorry for long response. with the way the world is right now...screw it! I'm still out riding! TOMG? I have your number and I'll give you a call!
    Thanks all,
    Doug (Pooh)
    200+ Posts
    NC Triker's Avatar
    Jul 2012
    Supply, NC
    Glad you made it home safely. I don't know anything about a Stallion so can't help you there. Thanks for the update.
  1. Clutch is Stuck---HELP!!!
    By drumdoctor in forum VW Powered Trikes
    Last Post: 06-12-2017, 06:43 PM
  2. Help my CD player is stuck!
    By Boscoporp in forum Honda Trikes
    Last Post: 08-05-2011, 08:40 PM
  3. stuck starter
    By EZglider in forum General Discussion
    Last Post: 10-04-2010, 03:09 PM
