14TG114TGHarley Tri GlideInstallation of a new Fuel Filter &...
BigN693GorillaEnabled TrikersFull length floorboards
Results 1 to 5 of 5
Thread: Where are pots for adding R-14 to AC system?
    60+ Posts
    Aug 2009
    Richland, WA
    Default Where are pots for adding R-14 to AC system?
    Had Stallion out this afternoon. First time in a while. Of course, it's 90+ outside so I thought I'd run the AC. No cooling. Took me a while to figure out the Vintage AC setup & still, no cooling. Confirmed at home that the compressor was not locked up, so the next option was to add refrigerant. Couldn't see the low & high pressure Schrader ports for adding R-14.
    Has anyone pursued this task and, if so, how accessible are the high/low pressure ports?
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    Quote Originally Posted by Markie View Post
    Behind the right tire. If I remember about the 2 o'clock position. Tomg
    right as always Tom thats where I saw mine
    350+ Posts Doc7402's Avatar
    Mar 2013
    Thonotoassa ,Fla ,USA
    i guess you did look and see if the compressor was coming on not,it does have a low pressure switch if to low.
    60+ Posts
    Aug 2009
    Richland, WA
    Default Results
    Placed gauge on low side port: read ~ 10 lbs with compressor running. Shot 12 oz R-134A into system & low side pressure rises to ~ 30 lbs & cooling is now coming from vents. Put additional 6 oz into system & low-side pressure up to 40 lbs.
    For all who replied, let me say thanks. Saved doing a hand-over-hand analysis of the A/C lines.
    Markie
  1. Thanks for adding!
    By Trk Ldy in forum Indian Trikes
    Last Post: 10-25-2015, 06:28 PM
  2. adding a CB since the '14 didn't come with one
    By MB1953 in forum Harley Tri Glide
    Last Post: 09-25-2015, 08:24 AM
  3. Adding Chrome edging to Roadsmith Trike
    By mgwtrike in forum Honda Trikes
    Last Post: 04-05-2015, 11:54 PM
  4. Adding images to threads
    By geezerglide11441 in forum Harley Trike Conversions
    Last Post: 08-23-2013, 11:44 AM
  5. Adding the 3rd wheel
    By wingking51 in forum New Member Introductions
    Last Post: 01-01-2010, 12:43 AM
