JTJersey3Jack KlarichHarley Freewheeler /...Removing Trim Around Oil Cooler
JTJersey3JTJerseyHarley Freewheeler /...Removing Trim Around Oil Cooler
JTJersey3rhino 2Harley Freewheeler /...Removing Trim Around Oil Cooler
B SMITH9rhino 2Harley Tri GlideTrailering Tri Glide
B SMITH9CasperHarley Tri GlideTrailering Tri Glide
Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
ken g9Old Road DogHarley Tri Glidereverse not working
AriNV13trike ladyNew Member Introduct...New to trike
AriNV13GorillaNew Member Introduct...New to trike
AriNV4GorillaCan Am Spyder Trike...I'm a total newbie ... Is the Spyde...
Grandpot9Papa ZookHonda TrikesFront tire?
Grandpot9tourmanHonda TrikesFront tire?
AriNV13Marc HNew Member Introduct...New to trike
Burnerboy4pawsRoadsmith Trikes
Too Pa Pa Zook
AriNV13Uncle FesterNew Member Introduct...New to trike
Jack Klarich2Jack KlarichGeneral DiscussionMY first guitar
Jack Klarich2ZammyGeneral DiscussionMY first guitar
Too Pa Pa Zook
Hdsteal4Jack KlarichSuzuki - Kawasaki Tr...Completed MS Trike Pics
Noodles1078Jack KlarichHarley Freewheeler /...Very Nice Gloves
Noodles1078Papa ZookHarley Freewheeler /...Very Nice Gloves
Likes Likes:  6
Results 1 to 11 of 11
Thread: loose handlebarss
    40+ Posts
    Feb 2016
    Des Plaines, IL USA
    Default loose handlebarss
    good morning
    My handlebars came loose today.
    I'm hoping it is a simple tightening?
    How do you get to the bolts to tighten? is there a way to open the top of the shroud?
    It looks like it's an access door, but I don't want to stick a screwdriver in there to pry it off if it's not supposed to.
    Any help would be appreciated.
    Mcmister
    Chicago
    300+ Posts
    Mar 2018
    Waelder, Texas
    That cover is removed easily. You can slip a credit card under it and pry. You can then get to two of the clamp bolts.
    200+ Posts
    Sep 2018
    Pa
    Default Torque
    16 to 20 foot/pounds
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    This is from the service manual for my 2017 FW
    HANDLEBAR 2.15
    ADJUSTMENT: FLRT
    FASTENER TORQUE VALUE
    Upper handlebar clamp
    fastener, rear: all models
    16–20 ft-lbs 21.7–27.1 N·m
    1. Remove trim insert from riser cover.
    2. Loosen handlebar rear clamp screws one half turn.
    NOTE
    Measure at a right angle to the straight edge.
    3. Place a straight edge across the
    windshield bushings.
    4. Measure from the straight edge to the front of the
    handlebar just below the upper bend.
    5. Rotate the handlebar in the risers until the gap measures
    4 in (101.6 mm).
    6. Tighten rear clamp screws to 16–20 ft-lbs (21.7–27.1 N·m).
    7. Install trim insert.
    40+ Posts
    Feb 2016
    Des Plaines, IL USA
    Thanks for the info. Much appreciated.
    I assume the insert cover is the black piece of plastic around the fork lock?
    I'm told under this cover are 2 screws that need to be removed... then the shroud (riser cover?) can be removed?
    from there the service instructions are clear.
    Thank you again
  6. #6
    200+ Posts
    Sep 2018
    Pa
    Default Hex
Size:  465.9 KB. This is picture of back of
    plastic and 1/4 inch hex inserted into bolt heads
    Shroud DOES NOT have to be removed if you have hex long enough to reach bolts.
  7. #7
    200+ Posts
    Sep 2018
    Pa
    Default Bar adjustments
    I have 14" bars on my fw so i adjusted them to be comfortable for " me". The manual basically tells you to run a straight edge up the from legs and have a specified distance from bars to the straight edge. Not critical , in "my" humble opinion.
  8. #8
    150+ Posts GTK's Avatar
    Oct 2018
    Hobe Sound,FL
    Quote Originally Posted by RKplus10 View Post
    I like the credit card approach to get cover off. I used a small screw driver and still gouged the plastic edge of cover.Have to remember that.
  9. #9
    40+ Posts
    Feb 2016
    Des Plaines, IL USA
    Oorah!
    Picture worth a thousand words!
    Thanks bunches and bunches!
  10. #10
    10+ Posts
    Jan 2020
    KENNESAW
    Default Thank you for photos of handlebar access plate
    Tucci:
    Thank you for the photos of the handlebar access plate. Those have made all the difference in the world as I had no idea what the full assembly looked like.
    I'll use my plastic automobile door trim removal set to get the plate off.
    My bars are not loose but appear to not be centered left to right; maybe my eyes are just crossed.
  11. #11
    5+ Posts
    May 2020
    Plains MT
    Quote Originally Posted by Tucci View Post
    Curious about your 14" bars. What kind are they, and did you install them yourself? Need the bars a bit closer and wondering if 2" more than stock would require any longer cables or is there enough slack?
    Thanks in advance!
  1. loose control knobs
    By wildwest in forum Stallion Trikes
    Last Post: 03-26-2012, 10:16 PM
  2. Loose Crash Bar rings
    By Las Vegas Biker in forum Stallion Trikes
    Last Post: 11-06-2011, 09:53 PM
  3. 2011 Tri Glide - Loose oil pan!
    By ehroyal in forum Harley Tri Glide
    Last Post: 10-15-2011, 08:43 PM
  4. Loose Bleeder Valve
    By Gorilla in forum Stallion Trikes
    Last Post: 02-22-2010, 03:52 PM
  5. loose bolts
    By sprt220 in forum General Discussion
    Last Post: 08-31-2008, 05:53 PM
