Phu Cat1Phu CatGeneral DiscussionIs there a TV commercial
Speed Bleeders
Likes Likes:  0
Results 1 to 8 of 8
Thread: DK Air Deflectors
    Dec 2014
    Grand Junction, Co. USA
    Default DK Air Deflectors
    I put these on back in Late May. Before I go on ... I love them .. when I ride in shorts (anytime weather is over 70*) I can feel the increase of air coming to the inside of my legs which proves that they drive air where I need it ... keeping my legs cool and more importantly ... the engine cooler.
    So here is my question:
    I had totally forgotten about the little HD air wings on the outside of the faring (too many Gold Wings). On my post yard work ride this morning, the brain engaged and I remembered them. Angled them to push air towards my chest and was in heaven. It was only 85* so moving air still felt good. When I got home, I did the 360 in the cul-de-sac so I could back into the garage and when I took the bars all the way to the right I heard a scrape, but, it was quick. Bringing the bars back to the center I heard it again. finally figured it out, the bottom of the wings are rubbing onto the top of the air deflectors.
    I don't know if I installed them wrong ... but, they don't really fit any other way.
    Name:  AD Right.jpg
    They pretty much are "Form Fitting" ... I'm not giving them up, they are great at keeping heat off the feet "at speed" and air on the engine.
    Maybe I just need to remember to put the HD vent closed when I'm gonna make a all the way to the stop turn.
    There are now little "arches" on thew deflectors where the HD vent has scraped the air deflectors ... again, I'm not wanting to ditch them ... just checking if I installed them incorrectly ... DK does more product testing than any other company I know ... so I'm pretty sure I installed them wrong ... to be honest ... I can't remember if I read the directions ...
    450+ Posts TonkaDriver's Avatar
    Feb 2018
    Bagdad, AZ, USA
    Default Adjustment
    Hello Alan,
    the angle on your wing appear to be pointed at the front cylinder head. If you adjust them to point more toward the rear cylinder, will that give you more clearance? Just a thought.
    Kurt
    Dec 2014
    Quote Originally Posted by TonkaDriver View Post
    Hello Alan,
    Kurt
    I'll play with it, but, if I move them more down in the front, they could vibrate against the lowers ... ... they are centered with even gaps all around .. maybe Kevin will chime in ... in the mean time ... I'm taking the position that I don't care if they rub ...
    Dec 2013
    Clarion PA USA
    Fuzz they look just like mine ride safe Fred FYI Name:  DSC00223.JPG
Size:  160.8 KBmine will rub a little also these we first run on old shiney
    Feb 2018
    Bagdad, AZ, USA
    Default Mine Rub Too
    I checked and with the fairing vents turned and mine hit also. I will be sure to be careful about that.
    Kurt
  6. DKCustoms postbit
  7. #6
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Hey Alan,
    It is a tight fit, but it should work when you have everything lined us just right. Yours look a bit pointed up.
    Here is a link to the instructions. https://www.dkcustomproducts.com/med...structions.pdf
    In the second to last paragraph before the "General Notes" it says the following (but I recommend reading the entire link above)-
    Once it is almost snug, rotate the CDW to the angle you want. Carefully turn the handlebars allthe way to the right, making sure there is no interference. Once you have determined that youcan turn the handlebars from side to side with no interference, and that you have at least ¼”space between the CDW and the lower fairing, go ahead and tighten it down.
    www.DKCustom.com
  8. #7
    650+ Posts
    Sep 2015
    Sheboygan, WI
    Fuzzy, yours look more verticle than I have mine set. Mine are a little more flat to get more air to the rear cylinder. I also bent mine very slightly after install but no rubbing now.
    It is what it is.
    16 Tri Glide vivid black
  9. #8
    Dec 2014
    Hey Alan,
    Kind of what I figured ... I've never been big on instructions ... Having said that ...
    This morning ... like first light 0545 (5:45 for the landlubbers ... LOL) I was out "playing"
    I remove the HD Vents, got out my grinder and file. Did a grind on both of them to remove about a 1/4" ... kept the same angles and curves ... then filed it smooth, and put a long match on the filed part to make them shinny ...
    Before:
    After:
    Patience was never a virtue of mine ... LOL .. so now I have the same air flow ... and no rubbing ... My dad used to say, "Sometimes there are two ways to do things ... the right way ... and Alan's way"
  1. GL1800 newer air deflectors
    By Hocky in forum Honda Trikes
    Last Post: 05-26-2015, 10:48 PM
  2. Mid-Frame Air Deflectors are back from paint
    By Keystone in forum Harley Trike Conversions
    Last Post: 03-28-2015, 07:23 AM
  3. Air Deflectors
    By Trent in forum Harley Trike Conversions
    Last Post: 03-23-2015, 06:47 PM
  4. Baker vs Show Chrome Air/Wind Deflectors
    By paws in forum Honda Trikes
    Last Post: 08-22-2012, 09:24 PM
  5. Baker Mirror-mounted Air Deflectors...???
    By skuuter in forum Accessories
    Last Post: 09-01-2010, 12:53 PM
