Gernerwa10Jack KlarichNew Member Introduct...New Member from Bellingham, WA
Gernerwa10trike ladyNew Member Introduct...New Member from Bellingham, WA
Gernerwa10GorillaNew Member Introduct...New Member from Bellingham, WA
Gernerwa10rhino 2New Member Introduct...New Member from Bellingham, WA
Gernerwa10Marc HNew Member Introduct...New Member from Bellingham, WA
Gernerwa10Uncle FesterNew Member Introduct...New Member from Bellingham, WA
Gernerwa10ZammyNew Member Introduct...New Member from Bellingham, WA
Gernerwa10hardwickbvNew Member Introduct...New Member from Bellingham, WA
Gernerwa10ol' schoolNew Member Introduct...New Member from Bellingham, WA
Gernerwa10GernerwaNew Member Introduct...New Member from Bellingham, WA
Speed Bleeders
Likes Likes:  20
Thanks Thanks:  2
Page 2 of 2 FirstFirst 1 2
Results 21 to 26 of 26
Thread: Cloudy Hydraulic Clutch Fluid Explained By Dealer After Flush
  1. #21
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    That should work good
    Best of luck
  2. #22
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Keep in mind with brake fluid once the container is opened the clock is ticking
    Meaning the fluid will start absorbing moisture
    When I taught brake class it never failed , I would see 5 gallon cans of brake fluid in the shops with NO tops on
    I always had my meter with me so I would check the fluid. 9 out of 10 times the fluid was contaminated. Glad I was not responsible for paying for the fluid
  3. #23
    90+ Posts
    Jun 2018
    Forney, Texas, USA
    Hi Rhino 2, What I am trying to do is periodically replace the majority of hydraulic clutch fluid without having to remove the transmission outside cover to bleed the clutch line. Today, I attempted to remove the transmission outside cover and there is simply not enough room between the downpipes and Trike frame to remove the bottom portion of the transmission cover. In turn, to have enough room, I would have to loosen/remove the Trike's aftermarket downpipes. Thanks for your response. Allen S.
  4. #24
    90+ Posts
    Jun 2018
    Forney, Texas, USA
    Thanks Jack, When I purchase the new DOT 4 hydraulic fluid, I will use what I need and the remaining will be disposed. In turn, if this process works, my plans are to make it a yearly one using newly purchased hydraulic fluid at that time. Once again, thanks for all the help. I will eventually get there. Allen S.
  5. #25
    2250+ Posts radismukes's Avatar
    May 2018
    Angleton, Texas
    Allen
    Texas have consumer protection laws for repair work. Check out this link.
    https://www.texasattorneygeneral.gov...ar-repair-tips
    Good Luck!
    “Come and Take It!” “Remember the Alamo!” “Remember Goliad!”
  6. DKCustoms postbit
  7. #26
    900+ Posts
    Apr 2011
    Bellville, Texas, USA
    Quote Originally Posted by keikat2 View Post
    .....In turn, if a person wanted to periodically update new clutch fluid into the clutch system, wouldn't it be possible to remove the clutch reservoir cover, remove all the reservoir clutch fluid and any debris from the reservoir bottom, add new fluid to the indicated "fill" line, place the reservoir cover back on and reinstall the cover screws. As long as the clutch lever is not pulled-in during this process, no air should enter the clutch lines.
    This is exactly what I have done on my bikes for several years. At least twice a year I use a syringe and suck all of the fluid out of my clutch and brake reservoirs, wipe out the reservoirs and add new fluid. So far I have never had any problems with my clutch or brakes. Not recommending this just saying that it works for me.
    Sunman
  1. Help, windshield cloudy gl1800 windshield
    By jnorth in forum General Discussion
    Last Post: 09-13-2019, 10:09 PM
  2. Has Anyone Flushed Their Hydraulic Clutch System?
    By MDO in forum Harley Freewheeler / Road Glide 3
    Last Post: 01-31-2018, 07:01 PM
  3. Replies: 10
    Last Post: 10-10-2017, 06:53 PM
  4. Hydraulic clutch too hard to pull
    By Huelshorst in forum Harley Tri Glide
    Last Post: 03-17-2016, 11:49 AM
  5. New Build Hydraulic Clutch/Brake Clutch Pedal Fabrication
    By usnavy8084 in forum Home Built Trikes
    Last Post: 10-21-2012, 08:18 AM
