Results 1 to 3 of 3
Thread: Lights dimming
    200+ Posts
    May 2013
    Mackinaw Il usa
    Default Lights dimming
    Now I have my fog lights working, my lights dim when I put the brakes on whether I have them on or not but they only dim for a second and then normal.
    950+ Posts JaysGone's Avatar
    Nov 2012
    Delray Beach Florida
    If the fog lights are on the same circuit as the brakes or headlights. You might be pulling too much amperage for the line in question.
    Check your battery for proper voltage at least 13.8 while running 14.1 is better.
    If under 12.4 when the bikes off and cold. Not great. The bikes meter is good enough to be useful.
    If battery isn't an issue next might to check might be the main ground straps. Make sure they are good and tight and clean.
    Dimm lights for me has always been a battery or charging issue.
    200+ Posts
    May 2013
    Mackinaw Il usa
  1. Replies: 4
    Last Post: 04-17-2018, 10:01 AM
  2. running lights/tail lights
    By JerryC in forum Stallion Trikes
    Last Post: 04-13-2018, 05:28 PM
  3. Which LED lights for the rear tail/brake lights
    By 470004 in forum Harley Trike Conversions
    Last Post: 11-20-2014, 08:13 PM
  4. driving lights and head lights
    By Dragon in forum Stallion Trikes
    Last Post: 10-05-2014, 09:25 PM
  5. LED Lights
    By katfish16 in forum Accessories
    Last Post: 09-08-2010, 07:26 AM
