Likes Likes:  10
Thanks Thanks:  1
Results 1 to 18 of 18
Thread: Rear Tire replacement
    60+ Posts ProudTexson's Avatar
    Dec 2012
    Big Spring Texas
    Default Rear Tire replacement
    i need to Replace rear tires on my Suzuki C50 Lehman Tramp. It has 205 60 15 Dunlop on it now. Does anyone have any suggestions on a replacement tire. I am something that would have good traction wet and dry. Good handling and comfort. Thanks for any help you can give.
    Quote Originally Posted by ProudTexson View Post
    Dave forum search rear tires this has been discussed several times.
    Dec 2012
    Big Spring Texas
    Thank You for the reply. I have done that. I haven't found anything on tire brand or peticuler tire. I have found about sizes and such. But I will keep looking. My tires still have plenty of wear left. 2008 Suzuki Tramp are starting to show cracking at bead.Thats not good in this West Texas heat. Would like to put something good instead of the Dunlop thats on it. Thank you again. The Proudtexson
    Dave, have a look at Good Year Comfort Treads Very good wet handling tire
    If you have Discount Tire Shops give them a price check
    A T rated tire would be fine for a Trike
    Dec 2012
    Big Spring Texas
    Thank you. Been looking at DT.. Thats where I buy most of my auto tires.
    dave i typed in trike rear tires in the forum search engine and got over 60 responses. i looked at several and besides the aforementioned goodyears there are several other suggestions. select the forums tab then type trike rear tires in the advanced search window on the right side of the page. good luck there is alot of information available there
    Dec 2012
    Big Spring Texas
    Thank You I found all you pointed out. Got it figured to Good Year or Cooper. I use Discount Tire.I will see what they can get for me. Thanks again for the Help. I wasn't searching correctly. Dave
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Cool
    Dave, you might consider a 205/70/15 instead. The 70 series tire is about 3/4" larger in diameter but has a bigger shoulder and offers a more cushioned and smoother ride when running 20psi. Your speedo runs from the front wheel so no error there.
    Jim Murphy
    Iron Butt Rider 2001
    Dec 2012
    Big Spring Texas
    There you go again giving good advice. I like cushion and smooth. This old 79 year old body needs all the help it can get. There isn’t an overpass in west Texas that doesn’t have a bump getting on it.
    Thank you I will do that.
    Dec 2012
    Big Spring Texas
    That would also lower my RPM at any given speed also would it not. Could result in a little better fuel mileage.
    Martinsburg, WV
    Cool
    Probably not really noticeable though, 100 lower rpm's and maybe???? better mileage.
    Jim Murphy
    Dec 2012
    Big Spring Texas
    Mr Mann Are the spoke wheels on the rear of my Tramp tubeless thank you
    Lee......AKA Jim is no longer with us......He passed a short while ago.......
    Dec 2012
    Big Spring Texas
    So sorry to hear that He will be missed from this forum RIP Jim
    Dec 2012
    Big Spring Texas
    Does Anyone Else know
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    I would think tubeless.
    Unless the inside of the wheels are sealed spoke wheels usually need tubes ‘ If There is a nut holding the valve stem’s against the wheel that’s a tube… Also check the sidewalls on the tire it might say tube only ?..
  1. Avon AV-71 Front Trike Tire - anyone using this tire???
    By dadztoy in forum Outrigger Style Trikes
    Last Post: 02-16-2024, 04:24 PM
  2. tire size for rear tire on front? 2007 goldwing trike
  3. Rear Tire Changing
    By firebreath in forum Honda Trikes
    Last Post: 11-09-2009, 04:00 PM
  4. Rear tire presure
    By Wayne Harmsen in forum Honda Trikes
    Last Post: 06-01-2009, 03:22 PM
