Likes Likes:  1
Results 1 to 14 of 14
Thread: Champion Mechanical Reverse
    10+ Posts
    Aug 2019
    Arnol, Penna, USA
    Default Champion Mechanical Reverse
    I just bought from an HD dealer a 2006 Ultra that has a California Sidecar kit installed. The bike also has a Champion mechanical reverse installed but the shift lever won't engage, the dealer disclosed this at the time of the sale and reduced the price. Does anyone have any suggestions for how I would start trying to figure out what is wrong. Lastly, when I say the lever won't engage, I can't move it at all. From what I understand you push the lever in and then up but it will only move very very slightly.
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Kevin.......Welcome to Trike -Talk..........
    .I'm sure someone will chime in with help..
    '''''''''''Pappa Zook??
    ....I had the Moto-trike reverse and that only moved a half inch or less to get it in or out of reverse...
    But that is a different setup than the champion....
    2019 Tri-Glide.......
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    kevin welcome aboard. sounds like to me that you will have to remove the cover to see what has come loose inside that is preventing the lever from moving.
    10+ Posts
    Aug 2019
    Arnol, Penna, USA
    I intend on replacing the clutch and clutch cable in the spring so I was planning on looking into this then. I think I was just trying to see if anyone else had run into this problem and what it ended up being.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Quote Originally Posted by klkordzi View Post
    Give me a call and I will help you trouble shoot the problem.
    346-800-7946
    Randy
  6. #6
    Banned
    Apr 2018
    Clayton,NJ USA
    Default champion reverse
    Make sure clutch is engaged when using lever and that clutch cable is adjusted properly.
  7. #7
    90+ Posts
    Oct 2018
    Linden, TX
    Quote Originally Posted by chester View Post
    And still expect some crunch when putting in reverse. Takes some effort to get lever all the way down.
    Papa Zook will get u going.
  8. #8
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Quote Originally Posted by irondog View Post
    Like i said my Motor Trike was different from the Champion.....But i found that if i put the transmission in neutral push the lever into reverse , And then while holding the clutch in start the engine then ease off the clutch, It backs up with out any crunch.... ..
  9. #9
    90+ Posts
    Oct 2018
    Linden, TX
    Neutral Nirvana does not exist on my 98 Ultra.
  10. #10
    20+ Posts
    Jan 2018
    australia
    can anyone tell me why the champion reverse wont fit the early 5 sp thanks
  11. #11
    90+ Posts
    Oct 2018
    Linden, TX
    David, don't know what "early" is, but I have the old Champion reverse and raked trees on my '98. Not much info available on either. Papa Zook or Lee H. Mann would be your best bet. Ken
  12. #12
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    david why not call champion and ask them
  13. #13
    20+ Posts
    Jan 2018
    australia
    whats the difference in the set up thanks
  14. #14
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Quote Originally Posted by david lee View Post
    Don't really know.....Preference i guess.....My dealer only does the Moto-Trike reverse.. And he has been doing them since the Tri-Glide first came out..
  1. MotorTrike mechanical reverse
    By 470004 in forum Harley Trike Conversions
    Last Post: 06-19-2014, 02:34 PM
  2. Info on Triglide mechanical reverse??
    By DocnLou in forum Harley Trike Conversions
    Last Post: 07-02-2013, 07:10 AM
  3. hard getting into mechanical reverse
    By engprosinc in forum Harley Trike Conversions
    Last Post: 06-20-2013, 02:25 PM
