Results 1 to 3 of 3
Thread: Fork Extensions for 5.5 degree ez-steer on "07 GL1800 . . .
    10+ Posts Wind Therapy's Avatar
    Jul 2018
    Fredericksburg, VA, USA
    Default Fork Extensions for 5.5 degree ez-steer on "07 GL1800 . . .
    I'm trying to determine (without disassembly) if my 07' GL1800 w/2018 1800HTS RS trike kit and 5.5 degree EZ-Steer came with 2" front fork extensions. The trike definitely has a "nose-down" attitude, and I very much would like to level it out.
    Some say the extensions are part of the EZ-Steer Kit . . . some say they didn't come with the kit. My trike was built by Kevin Dodd of KD Cycles in Altoona, Alabama.
    I need to know the best method to level out my trike (raise the front end by extending the forks by +/- 2").
    Any guidance would be appreciated.
    Regards,
    Dave Calahan
    '07 GL1800 w/RS 1800 HTS Kit
    "Wind Therapy v5.0"
  2. Roadsmith banner
  3. #2
    Quote Originally Posted by Wind Therapy View Post
    Regards,
    Dave Calahan
    "Wind Therapy v5.0"
    I'm not sure you can tell sans disassembly, but, try PM'ing Papa Zook ... he's a trike builder and owns this site ... he can give you details on how to check and probably how to get the nose "up"
  4. #3
    300+ Posts
    Jun 2014
    S.E. Ohio,Close to the triple nickel
    How good are you at guessing length. You should be able to run your hand along the fork tube up under the fairing. Near the the top triple tree on the fork tube you might be able to feel where the plug screws into the fork tube. Then be able to estimate how far it is to the top of the extension plug.
    Last Thursday I removed the plug extensions on mine. There is spacer tubes between the extension pugs and the springs in the fork tubes. I cut a couple spacers (1-1/4") longer than what was in mine. This raised it up a about the same. I have 1" extension plugs,so I ordered 2" extension plugs from Papa Zook. Ordered on Friday and recieved them on Monday. Fast.
    I plan to add these this week. This should get my trike up a couple inches from where it started. I think it will be level when done.
  1. GL1800 & GL1500 Fork Tube Extensions For Sale
    By Cut N Shoot Customs in forum Cut N Shoot Customs
    Last Post: 02-14-2019, 01:02 PM
  2. Suzuki Raked Triple Tree Fork Tube Extensions
    By Yogisan in forum Suzuki - Kawasaki Trikes
    Last Post: 12-28-2011, 05:26 PM
  3. Degree of Rake & Springer Fork
    By standingbear56 in forum Harley Trike Conversions
    Last Post: 11-28-2011, 12:39 PM
  4. Fork stops for 7 degree rake on 2006 HD Deuce
    By blackwidowHD in forum General Discussion
    Last Post: 10-22-2010, 11:08 PM
