Likes Likes:  9
Thanks Thanks:  1
Results 1 to 13 of 13
Thread: Park brake
    Aug 2019
    Chilliwack, BC
    Default Park brake
    My Suzuki Boulevard C50 Lehman Tramp trike conversion (2007, I think) is at the full extent of its park brake cable adjustment.
    I need a new part.
    I am in Canada.
    Any help locating the part much appreciated. 😎
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Cool
    Quote Originally Posted by Helen Tramp View Post
    I need a new part.
    I am in Canada.
    Helen, Welcome to Trike Talk from West Virginia, USA.
    The Tramp has drum brakes that do occasionally need adjusting at the wheels, usually at 5-10K intervals.
    It sounds like someone might have been adjusting the brake shoes via the parking brake cables and not the proper way.
    My suggestion to you is to have the brakes adjusted properly first before considering a cable replacement.
    1. Back off the parking brake cables (each) about 1 "
    2. Adjust the brake shoes at each wheel (until there is a slight drag at each wheel, press down on the brake pedal several times and check or adjust for a slight drag)
    3. Adjust parking brake so that it applies at the 5th or 6th click on the handle.
    Jim Murphy
    Iron Butt Rider 2001
    Aug 2019
    Chilliwack, BC
    Default Thanks
    Thanks for this great, detailed advice. ❤
    It does seem odd this has happened, as the trike only had 3000km on it when I bought it, so it really cannot have had its brakes adjusted many times.
    Given its extremely low previous mileage, (and I have only owned it for one year) I was really surprised when I was told about the patk brake this time.
    Does that prompt any other explanations, or foes that still seem like the most likely scenario?
    Thanks for the consideration of my problem. 🌞
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    Helen! Hi! Welcome to TrikeTalk!
    Aug 2019
    Chilliwack, BC
    Hi, paws! 🌞
    Helen..........Welcome to Trike-Talk; ....
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Hi Helen. Welcome to trike talk Just check out LEE H. MANN advice, he is the resident expert on Lehman Trikes. The brakes could not be adjusted correctly by the original installer.
    Aug 2019
    Chilliwack, BC
    Hi rhino2 and Avatar.
    Thanks for the welcome. 😎
    I absolutely trust Lee H Mann's advice. He is obviously the expert.
    It is wonderful to have someone with that knowledge and ecperience willing to share it for free. ❤❤❤
    Thumbs up
    There is an abundance of knowledge here
    Martinsburg, WV
    Cool
    Another thought comes to mind, the original owner could have ridden the trike with the emergency or parking brake lever partially applied causing the shoes to wear prematurely too.
    Jim Murphy
    20+ Posts
    Mar 2019
    Columbus, GA, USA
    Default Lehman Bandit parking brake
    I'm not sure how close your conversion is to the Bandit that I used to have. But when I bought it, as a basket case that hadn't run in seven years, the parking brake didn't work at all. Being an old school shadetree mechanic, I had an old brake 'spoon' that is used for adjusting drum brakes. I think they are still available at some auto part stores.
    My rear brakes were so badly out of adjustment that I was amazed that they even engaged.
    USAF PJ, '64-'72, 3 Tour Vietnam Vet.
    Old Trike - 2002 Sportster with Lehman Bandit conversion
    New Trike - 2010 Tri-Glide Ultra Classic
    Martinsburg, WV
    Quote Originally Posted by RDinGA View Post
    Rich,
    It has the same basic system as your Bandit had.
    Jim Murphy
    Welcome to the Gang from Western Colorado.
  1. Park brake adjustment
    By y2k_harley in forum Harley Tri Glide
    Last Post: 02-11-2017, 05:17 PM
  2. Sidecar park brake pads?
    By peteg59 in forum Sidecar Forum
    Last Post: 07-31-2015, 03:48 PM
  3. adjusting the park brake
    By Capt Lou in forum Harley Trike Conversions
    Last Post: 03-29-2014, 06:22 PM
  4. Park Brake
    By kiorana123 in forum Harley Tri Glide
    Last Post: 03-28-2011, 11:55 PM
  5. Park brake for Champion Ultra mod
    By kiorana123 in forum Harley Trike Conversions
    Last Post: 12-05-2010, 04:29 AM
