dthorn1dthornHarley Tri Glide2024 Tri Glide front axle nut torqu...
Jack Klarich2ISP-FLGeneral Harley ChatExhaust Heat Shield
Jack Klarich2Jack KlarichGeneral Harley ChatExhaust Heat Shield
Likes Likes:  4
Results 1 to 14 of 14
Thread: reverse
    20+ Posts
    Jan 2018
    australia
    Default reverse
    why is it that i cannot find a reverse to fit my trike with the first 5 sp transmission thanks
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by david lee View Post
    I'm guessing because there isn't much of a call for one........
    2019 Tri-Glide.......
    20+ Posts
    Jan 2018
    australia
    i did hear something about the early 5 sp had a tapered main shaft not splined which is the problem. im after more info if thats why .thanks
    Gone But Not Forgotten
    Tech Contributor
    Lee H. Mann's Avatar
    Apr 2011
    Martinsburg, WV
    Just off the top of the head, the clutch release cover has a different bolt pattern on the pre-86 model 5 speeds.
    You could update yours to the later model cover, push rod, ball & ramp and trap door.
    Like above, there is not a large calling for the pre-86 models for reverse gear.
    Use this link for seeing what will work.
    http://partsfinder.onlinemicrofiche.....asp?make=hdmc
    Jim Murphy
    Iron Butt Rider 2001
    20+ Posts
    Jan 2018
    australia
    thank you pic of my old cover before converted to hydraulic
  6. DKCustoms postbit
  7. #6
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    It appears that a Champion Reverse Gear would work. You would need a different pushrod (longer) and I see a relocation of the header pipe since the reverse would move the cover at least 1/2" outward.
    Jim Murphy
  8. #7
    20+ Posts
    Jan 2018
    australia
    thanks. what header pipe are you refering to,front or rear.there is a gap of one and half inches from the rear one to the oil tank.do you know if champion and mmd are the same internal set up.my hd mech has just fitted a mmd to a harley and recommended that one but i think he forgot mines the early 5 speed.mmd said there transmission cover and trapdoor are different to mine the first pic is mmd. the 2nd is champion.i appreciate your input
  9. #8
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    I looked at the install instructions and found that kit to be easier to install than the Champion 5-speed reverse gear.
    I did notice 2 things:
    The front header pipe will need to be moved if it comes too close to the hydraulic slave banjo fitting.
    I am also not sure that the hydraulic slave cover offers enough clearance for the tension spring on the Zodiac.
    Better ask the mechanic who will be doing the work.
    https://beeldbank.prepublisher.com/p...2/ZDCX0652.pdf
    Jim Murphy
  10. #9
    20+ Posts
    Jan 2018
    australia
    Quote Originally Posted by Lee H. Mann View Post
    thank you mmd said the bolt on patten is different but it looks like my mech might have put on an adaptor plate to fit the hydro clutch but not sure.but the patten looks the same to me.my other concern is mine would have a tappered main shaft instead of a splined. do you think that would make any difference.i can not find the mmd instructions on the internet. thank you
  11. #10
    20+ Posts
    Jan 2018
    australia
    i did see the instructions
  12. #11
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    The tapered shaft is only a concern on the clutch side.
    The trap door side of the main shaft is not tapered.
    Jim Murphy
  13. #12
    20+ Posts
    Jan 2018
    australia
    thanks youve been a great help.that was my main concern.sorry for the questions but in your opinion do you think i will still be able to run my hydro clutch thank you
  14. #13
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    Cool
    With the proper length pushrod, you should have no problems.
    You might have to make your own pushrod.
    Jim Murphy
  15. #14
    20+ Posts
    Jan 2018
    australia
    youve been a terrific help lee h mann a mate said i might have to extend the clutch pushrod but the kit comes with one
  1. Reverse gear for a reverse trike
    By elwirth in forum General Discussion
    Last Post: 05-23-2019, 10:30 AM
  2. Reverse Or No Reverse?
    By GETRDONE in forum Harley Trike Conversions
    Last Post: 09-05-2015, 07:37 PM
  3. new reverse trike
    By Trike Man in forum Home Built Trikes
    Last Post: 10-31-2012, 08:25 AM
  4. Some of my fave "reverse trikes"
    By mkparker in forum Home Built Trikes
    Last Post: 01-09-2011, 05:53 PM
  5. Reverse trikes past and future...
    By ben721364 in forum Other Brands Trikes
    Last Post: 02-24-2008, 06:00 PM
