Likes Likes:  13
Results 1 to 18 of 18
Thread: syn3 or amsoil
    150+ Posts
    Jul 2019
    marquette mi
    Default syn3 or amsoil
    what synthetic for a 2019 Triglide at the 1000mile check
    Syn 3 is NOT a true full synthetic oil
    According to the "Material Safety Data Sheet" for H-D's SYN3, it is chemically a blend of 60% synthetic and 40% petroleum oils.
    20+ Posts
    Jun 2015
    Northern Minnesota
    Amsoil V-Twin 20W50 synthetic in all 3 holes. Absolutely GREAT!!
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    Someone should start an oil thread
    600+ Posts ISP-FL's Avatar
    Mar 2017
    Lake Suzy, FL USA
    Lets face it, changing engine oil at 5,000 miles shouldn't require synthetic anyway. These engine run pretty hot so I don't mind changing it at 5,000, but is a true synthetic really doing you any good unless you run it for 10,000 miles or so?
    I am not a mechanic, nor do I understand much about engines. I use Syn-3 in all three holes simply because Harley suggests it and it makes it easy for me to do the service myself. I have only owned 5 Harleys but it has always worked good for me and I have never had an engine issue.
    It is like a lot of things, personal preference.
    Current: 2019 Trike (custom 130ci T-Man kit with Darkhorse bottom end)
    With my 17 Tri-Glide, Because of the oil migration issue they change the oil in the trans/ primary to formula one?.....And drain and refill it every 8 hundred miles on their dime, but wasting my time on my dime.......
    2500+ Posts GARYD's Avatar
    GLEN ELLYN, IL. USA
    Quote Originally Posted by trikeman View Post
    HEY! Great idea. The other 20 or so oil threads are outdated by now. ROTFLMAO
    IBA#61162
    PATRIOT GUARD
    USMC
    Meme Master
    Jan 2014
    Farmington, NH USA
    Conventional, (non synthetic), oils tend to form sludge and other harmful engine deposits under extreme heat much faster than full synthetic oils. As we all know, or should know, internal engine sludge is not good. Especially in a mostly air cooled engine.
    If one only keeps his/her vehicles a few years and trades them in for new again, oil type probably doesn't matter. However it will become the next owners issue if not well maintained by the original owner.
    For the conscientious owner, nothing short of full synthetics will do.
    It all depends on which category you fall under...
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    I had the dealer install Syn3 at the 1,000 mile service because I was on the road.
    I kept it in till the 3,800 mile mark & switched to Lucas full synthetic motorcycle oil and immediately saw 10-15 degree drop in oil temps & smoother shifting. I recently changed my transmission fluid to RedLine with Shockproof & the shifting improved & smoothed out so much, it felt like tranny work had been done. It's that good.
    I have HD Formula+ in the primary, as I had 2 quarts to use up. I will then switch to Redline primary fluid.
    I am currently using Quicksilver motorcycle oil (from Walmart) in the engine & when I return from my trip I will install Redline motorcycle engine oil, then alternate between that and the Lucas, as I have a lot of each & both are very good.
    As far as filters, I have found Mobil 1, HD & K&N to all be quality oil filters.
    The bottom line here is, almost any modern oil will work if changed at regular intervals, but some oils are definitely BETTER than others.
    As far as verified proof, I had Blackstone Labs analyze the Lucas oil with a Mobil 1 filter after 2,300 miles on the oil & the report was very good for both after my FW was run in above 90 temps all summer.
    Jack, this thread will have to tide
    you over & feed your addiction till I start a new & improved oil/filter thread this winter.
  11. #10
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    I kept it in for about 3,800 miles & switched to Lucas full synthetic motorcycle oil and immediately saw 10-15 degree drop in oil temps & smoother shifting. I recently changed my transmission fluid to RedLine with Shockproof & the shifting improved & smoothed out so much, it felt like tranny work had been done. It's that good.
    I have been using only Lucas full syn for years,use straight 50 in both my 17 Tri Glide and my 02 Road King and never a engine issue. Besides i don't normally ride in temps under 40 plus my garage is heated.
  12. #11
    150+ Posts
    Firewrench22's Avatar
    Oct 2014
    Kingston WA USA
    Been using Mobil1 synthetic, just got back from Sturgis, there was an Amsoil dealer there that had a Harley idling in front of their booth all day. Only Amsoil and Love Jugs keeping it cool. Kind of amazing. Says something about both products...almost enough to make a guy switch oils.
    I put the Love Jugs on just for this trip because I figured I'd be sitting in traffic at some point. They worked good, kept the oil temp down.
    I wonder if that bike would stay running with anybody else's oil in there.
  13. #12
    GLEN ELLYN, IL. USA
    Quote Originally Posted by Firewrench22 View Post
    I would guess - - probably.
    IBA#61162
    PATRIOT GUARD
    USMC
  14. #13
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    I used Amsoil years ago in my 03 Ultra. At that time the advertised 10,000 mile changes with their oil & filter. I put over 100,000 miles on that bike on 10k changes. Never used any oil. I also put over 400,000 miles on a Chevy Duromax diesel pulling trailers all over the US to dealers.with Amsoil & a bypass system on 60k changes. Great stuff.
  15. #14
    Oct 2017
    St. Louis, MO USA
    It would stay running with anyone's oil in it. It does not address what kind of damage it did.
  16. #15
    Meme Master
    Jan 2014
    Farmington, NH USA
  17. DKCustoms postbit
  18. #16
    70+ Posts
    Jan 2018
    comanche,Oklahoma,usa
    Amsoil. I use that is everything I own.
  19. #17
    I bet the piston oil cooling jets did NOT work good @ idle
    I would NOT subject my bike to this punishment
  20. #18
    700+ Posts jjvw's Avatar
    Dec 2013
    Jenison, MI
    This will show what goes on when things get hot.
    https://www.amsoil.com/newsstand/mot...-this-extreme/
    I have been using Amsoil since the early 70s when I was racing sports cars. My engine oil capacity was only 3 quarts. I installed an oil temp gauge, because I was over heating. After 10 laps I was holding my hand over it. It was so high, I didn't want to see it! I started using Amsoil and my oil temp went down 50º. Instead of changing rod bearings after every race, I stretched it to 3 races before I looked at them. I put them back in and finished the season on them. The next season, I never checked them until the end. Rebuilt it and saved the bearings for spares, they were that good. The oil lasted a whole season. I recycled the used oil in my ice racer, which with 120,000 miles, leaked a lot. It was the only one that would start in the cold without a jump.
    I usually don't brag about Amsoil unless asked, but seeing someone started another dreaded oil thread.....
  1. Amsoil in a GL 1500????
    By Colorado Con in forum Honda Trikes
    Last Post: 10-22-2013, 12:54 PM
  2. Amsoil 20w50 or Amsoil 60wt
    By Moneywoes in forum Harley Trike Conversions
    Last Post: 07-19-2013, 09:32 AM
