AriNV5pawsRider Safety Discuss...Maybe silly but serious question, s...
AriNV5Pegasus1300Rider Safety Discuss...Maybe silly but serious question, s...
AriNV5cycle7447Rider Safety Discuss...Maybe silly but serious question, s...
AriNV5Jack KlarichRider Safety Discuss...Maybe silly but serious question, s...
AriNV5AriNVRider Safety Discuss...Maybe silly but serious question, s...
Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  1
Results 1 to 13 of 13
Thread: Trailer tire pressure ?
    60+ Posts
    Apr 2013
    Altoona Pa. USA
    Default Trailer tire pressure ?
    How much air pressure should I use in my tag a long cargo trailer tires ? The tire says 80 psi max. I will have around 100 lb in the trailer. I am thinking about 25 psi would be a good place to start. I know I could load the trailer ,wet the tires ,see where tread gives the best pattern. I want to know your results. What pressure do you run ? How much weight do you carry?
    Quote Originally Posted by Road Rider View Post
    If you use anywhere near 80 psi, at every little bump the tires will be leaving the ground...
    What does the trailer inflation label recommend ....
    250+ Posts rhino65's Avatar
    Aug 2016
    Atwood, Illinois United States
    Went from Illinois to Colorado & back with roughly 120 lbs. in a 180 lb. trailer with new tires and ran 25 psi. 2300 miles later tires are wearing even
    2002 GL1800 with CSC trike kit
    350+ Posts
    Jul 2016
    N Ky USA
    For what it’s worth between the 3 trailers I’ve owned and pulled I usually wind up somewhere between 28-32.
    60+ Posts
    Apr 2013
    Altoona Pa. USA
    I will have to look for the label
    May 2018
    Angleton, Texas
    I have a 97 Escapade trailer which we have use over 10 yrs. in like parts of the country. Loaded light and heavy 25 - 28lbs.
    Never a problem on hot, wet, and wind.
    Official Mascot Trail Blazer's Avatar
    Nov 2012
    huntington , texas
    Default Hello Don
    I have a older Dart 18 qf with 12" wheels. I probably cary close to 100 lb and only run 22lb in the tires, it has made many many miles with now problems.
    Apr 2010
    Shenandoah Valley of Virginia
    Guessing your trailer has two tires maybe? (some do have just one, I have seen custom tandem axle trailers with 4 tires)
    Guessing also, 4.80/4.00 X 8 is the size maybe? (I have a buddy with a home built utility trailer he hauls wood on until the axle bows using little 4.80/4.00 X 8 load range C tires that I mounted for him onto some galvanized wheels I gave him, I tell him it's a bad idea, I'd run 12s at least … or even 14s)
    Load range B = rated @ 590 lbs at 60 psi. maximum
    Load range C = rated @ 745 lbs at 90 psi. maximum
    Typicaly I run 30-40 psi in mine. The tires are cheap enough and my use is rare enough that I am not worried about wear, but I'd sure hate to have a tire overheat and blow the sidewall out due to low inflation.
    550+ Posts Gideon's Avatar
    Dec 2012
    Indianapolis, IN. USA
    Quote Originally Posted by radismukes View Post
    Had my trailer since 1982. I also keep the tires 25-28 lbs.
    150+ Posts Yogisan's Avatar
    Oct 2009
    Upper Marlboro MD, USA
    I have a Hannigan Sierra trailer and the owner manual says 30 psi cold so that's what I use.
    30+ Posts
    May 2019
    Apache Junction, AZ USA
    My Bushtec Turbo 2+ manual says to use 45 psi regardless of load. Does bounce a bit, but I'll tune the pressure on my next trip.
    Quote Originally Posted by birdguy45 View Post
    Doesn't bushtec have the tires that look like they are off a bike? Where most other trailers use tires that are like small car tires. If so then the pressure would be different in those because they need to stay rounded at the contact patch. Just my thought
    30+ Posts
    May 2019
    You are correct, Gorilla. The tires are also used on dirt bikes and, of all things, some baby carriages. They have an aggressive off-road style tread, so will certainly require different pressures than car-style tires. Good catch…I should have thought if that🥴.
  1. Trailer and Air Pressure in Trike Rear End
    By Calman in forum Trailers / Campers
    Last Post: 09-11-2019, 07:56 AM
  2. Trailer Tire Pressure
    By jc1300 in forum Harley Tri Glide
    Last Post: 04-12-2018, 04:17 PM
  3. Tire Pressure Thread
    By WEB in forum Tires, Wheels, Brakes, Front End
    Last Post: 06-17-2014, 08:42 AM
  4. tire pressure???? suspension pressure???
    By flangar in forum Stallion Trikes
    Last Post: 05-10-2014, 09:53 PM
  5. Tire Pressure for Trike and Trailer
    By joelin5386 in forum Harley Trike Conversions
    Last Post: 09-12-2011, 07:03 PM
